2015 f550 axle
stroker_1999
Will a axle from a 2015 f550 work in a 2008 f450 I believe everything is the same other than the abs part can I use the hub bearings from the 2008 year along with the abs sensors for the 2008 in the 2015 axle.I have a customer with a 2008 f450 he wants to do a 4x4 conversion I found this great deal I just don't know if there's is any difference with the abs part besides the sensors I know the connector is different on the plug.Any help would be great I know when you do the 05 axle swap in the older 99-04 trucks you just swap the abs sensors I don't know if that's the case what this or not.
co04cobra
WV
The bearings swap over. Sway bar end links are usually different but very simple things to change.
If you run across any more deals on a F550 front shoot me a pm.
