Stock hight with 33x12.50 20's
Zstock6.4
You'll have to do some major trimming to clear them. Leveling kit is needed.
kealiher2004
Levant, Maine
I wondered. I bought a set of 2011 lariat wheels. I wonder if i go with the three leaf spring pack in the front if that would be enough, but will i have to get a drop style pitman arm?
kealiher2004
Levant, Maine
And if i do i am sure i would need different swaybar endlinks aswell. Go figure after i bought 100$ mooge ones two-three months ago..
Koda22
Ruidoso, NM
So most can fit that tire no problem. You will need to look into spacers if you plan to run 2005+ wheels though...that is if you drive an 04.....backspacing is all different.....but correct backspacing you can run 35s with a leveling kit and 33s stock...
strokin6L
Springville NY
You can run that size tire without any issues...but that depends on what back spacing and offset wheel you're gonna run. I'm running a 33x12.5x18 tire on a 18x9 wheel(4.5" back spacing, -12 offset) and have no issues with rubbing on stock suspension. Back spacing on a 04 truck is 4.5" and back spacing on 05+ trucks are almost 6".
kealiher2004
Levant, Maine
Humm i am currently running 305/70/16 on stock 04 alum wheels. On really tight turns they rub on leaf springs but that dont bother me i just know not to go stop to stop. Thanks guys i guess ill have to get them mounted and do a test fit. If i need spacers who makes good quality ones and how much? I know i bought adapters for one of my old silverados and always had a slight shimmy. Pissed me off :/ not looking to deal with that again
strokin6L
Springville NY
Mine are 305/60/18. Yours are a tad taller than mine....around 32.8" and mine are 32.4". Probably just enough to rub when at full turn.
kealiher2004
Levant, Maine
Yea i just put one of my new 33's up against my 305's almost identicle. Now to find some good quality spacers.. woundering which would be better 1.5" or 2". I have very lil invested in the new wheels so i am ok with spending the extra on spacers. I am pretty stuck on the looks of these 2011 lariat wheels. I think they are beautiful wrapped in a nice wide mud tire.
rentstdi
I have an 06 with stock 275/65 r20. That is 34.1 inches. Stock rim
I wouldn't want to use a spacer on a heavy truck. especially if you tow a lot
Monster12valve
Mentor, Ohio
The spacers that bolt on to the stock studs, then the wheel bolts to the spacers studs are good. The plate spacer that just goes in between the wheel and the hub are no good.
kealiher2004
Levant, Maine
Honestly I rarely ever tow anything but the wheeler once in a blue moon. Thisvis all really good info. Thanks guys i pm'd a vendor on here that has a set in classifieds. Hopefully 1.5" will give me enough back spacing
TequestaStroker
I run a 33x12.5x20 with a leveling kit and it's fine... I couldn't fit anything bigger, but it works.
strokin6L
Springville NY
Here's what my 33x12.5x18's on 18x9 wheels look like with stock height.
