Hey guys,
This is Jon and I own Carrick Customs. We specialize in high quality aftermarket parts for OBS Ford trucks. Our number one seller is our OBS Ford Heavy Duty Steering Linkage Kit. This steering linkage is for trucks equipped a Dana 60 front axle. It is far stronger than stock steering linkage and utilizes larger tie rod ends that do not wear out nearly as fast as the stock tie rod ends. We use low misalignment dust boots, on the TRE's that go to the knuckles, that eliminates the tie rod roll that causes the "dead spot" in your steering wheel. This steering kit is also much less expensive to maintain because you are able to replace the individual tie rod ends for $35-$40 each instead of having to replace nearly the entire tie rod or drag link (on factory steering) when the TRE wears out, which is more than 2x what our tie rod ends cost.
https://www.carrickcustoms.com/colle...y-steering-kit
We have also developed a coilover front suspension kit for these trucks that we hope to have available around the beginning of 2019.
We love making these trucks better and better and just wanted to share what we offer with people that have the same passion for these OBS Fords!
-Jon
-Jon
