Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 01-13-2018, 03:29 AM
BIG JUICE's Avatar
BIG JUICE BIG JUICE is offline
Lieutenant
Member's Gallery
Default Carli springs, OUO bars with bags, need help
Picked up my 2.5" carli deaver springs from Josh today, (thanks man!). Trying to figure out how to get bags and OUO traction bars mounted. Also blew a seal on fox shocks today, but another thread...
I have 2.5" Carli Deaver springs which I intend to use OUO bars (sitting in office-need mounts)and some kind of air bags with. I like the daystar bracket non attached idea, but honestly I don't off-road my $60k truck. However I'd still like articulation trying to get toys and equipment into the woods. I know Carli makes bags but they won't work with 2.5" lift. I plan to upgrade to 37" Toyo rts (have 35" now, plenty of room)on the stock platinum wheels and prefer not to collapse a fender with a load and offroad. So I definitely need a bag, prefer biggest bag I can fit. But why I stated about shock, I don't think it's conscience the shock next to 5" pipe leaked today was real close to extreme heat for 8-9 hour ride
__________________
2015 F250 platinum, flopro 5", jones turbine 5050xl, polished No Limit stage 2/pg 7 and prefilter intake, h&s intercooler pipe(throttlebody-gone) and half ccv reroute, jenny craig, sotf gear hedd tune, Rigid DOT fogs, Chinese 40" radius led, amp steps, weathertechs, edge cts2, titan tank, dieselsite fuel filter, blue ox gooseneck, Hellwig bars, retrofit projectors, linex plat, retrax cover,full Carli 2.5" backcountry,fox 2.0 res shocks, toyo rt 37", OUO ala & bars
  #2
Old 01-14-2018, 05:25 PM
WHY NOT's Avatar
WHY NOT WHY NOT is offline
Colonel
Member's Gallery
Default
I have firestone bags mounted to the OUO blocks on my truck, works pretty well. I have heard the 2wd bags for our trucks are a bit longer to give you a little extra. The daystar cradles are a good idea I need to get some for my truck, I got under it to clean it this winter and noticed I have both my bags torn from going threw ditches and what not.
__________________
Matt
2011 F350 6.7L CC/LB SRW 4x4 King Ranch White Tri Coat
Midwest, NL, GH - OUO/Icon 3.5"/6" on 20x12 Weld Cheyennes w/ 35x13.50's
  #3
Old 01-14-2018, 07:25 PM
BIG JUICE's Avatar
Lieutenant
Member's Gallery
Default
ordered 2wd air lift bags today, Guess I need day star cradles and OUO under axle mounts. I forgot to metion I have a blue ox gooseneck, not sure if air lift mounts will work
__________________
  #4
Old 01-14-2018, 07:37 PM
Jomax's Avatar
Jomax Jomax is offline
General
Member's Gallery
Quote:
Bummer, I have hellwig Big wig bags for a 2wd I would’ve sold for less the new. Never used brand new in the box.
Was meant for my 2015
__________________
2017 F-250 KR CCSB 4x4- 4400 coils, rear block removal, 20x10 novakanes, nitto 420s, king shocks, OUO traction bars, 5in Alum Driveshaft.
  #5
Old 01-15-2018, 08:58 AM
BIG JUICE's Avatar
Lieutenant
Member's Gallery
Default
they have brackets? I bought them for $82 shipped from amazon. warehouse deals open box lol. I am interested though, pm me
__________________
  #6
Old 01-26-2018, 05:02 AM
Poglife's Avatar
Poglife Poglife is offline
Sergeant
Member's Gallery
Default
How much you want for them and what all is included
  #7
Old 02-16-2018, 12:25 PM
BIG JUICE's Avatar
Lieutenant
Member's Gallery
Default
well neither the big wig or air lift will fit with my 5th wheel and these springs. air lift mounts on top of top plate which can not happen the way I have stock top plates. the big wig will work after i modify the top bracket I think. it won't bolt up with the 5th wheel plate on outside of frame rail
__________________
  #8
Old 02-19-2018, 06:25 PM
Spatel23's Avatar
Spatel23 Spatel23 is offline
Mod Squad
Member's Gallery
Default
an idea for your shock being close to the exhaust....wrap that portion of exhaust in header wrap.
  #9
Old 03-08-2018, 09:05 PM
Wayne's Avatar
Wayne Wayne is offline
Major
Member's Gallery
Default
I built a full kit for just this application, but on a '17 a while back using the Daystar pucks. Nothing I saw stock would work so I fabbed it all up, and welded mounts to the axles. It works fantastically, but welding is a big commitment. I might dig up some pics to give you an idea maybe of what to do
__________________
'15 F-350 Lariat CCSB 6.7 vermillion red. Basic 5" exhaust, tunes on a10" OUO lift & 40's
'08 Excursion 6.4 pearl white 700ish rwhp
  #10
Old 03-09-2018, 06:48 AM
BIG JUICE's Avatar
Lieutenant
Member's Gallery
Default
post pics.
so far I have wrapped the pipe with header wrap. Have the traction bars and springs working, have not modified the upper brackets for fit at the fifth wheel brackets. I will take a few pics today.
had to pull my sway bar off as the links will hit the springs under flex
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
