Go Back   PowerStrokeArmy > Power Strokes > 6.4 Tech
Reply
Thread Tools Display Modes
  #1
Old 01-13-2018, 02:27 AM
JumpMan92 JumpMan92 is offline
Private
Member's Gallery
Default Cracked Heads Question
Will cracked heads cause unburnt diesel in the cylinder? Recently had my heads off the mechanic recommended new heads but was tight on cash and the truck came back smoking diesel the truck ran away i towed it to the shop and it started up fine but it ran away again on a test drive. Fingers crossed the block is fine
File Type: jpg 6796214C-6871-4E20-AADE-16CF81CF4569.jpg (10.3 KB, 36 views)
  #2
Old 01-13-2018, 08:25 AM
Dzchey21's Avatar
Dzchey21 Dzchey21 is offline
Super Moderator
Member's Gallery
Default
Shouldn’t cause any of those issues. I would be more inclined to say turbos or injectors. Hard to say given the information stated.
__________________
2017 F-350 DRW Platinum stock for now
1979 F-150 6.0 Swap in progress, 86mm LP turbo, 04 frame and interior
  #3
Old 01-13-2018, 12:12 PM
Private
Member's Gallery
Default
I sent the truck in for new up pipes and the the truck has a little tapping noise which one mechanic said it was a lifter and it ended up being a rocker arm and then this
  #4
Old 01-13-2018, 06:09 PM
webb06's Avatar
webb06 webb06 is offline
Colonel
Member's Gallery
Default
Quote:
Why were the heads taken off then?
  #5
Old 01-13-2018, 07:16 PM
Private
Member's Gallery
Default
Quote:
Thought the tapping was the lifters but ended up being a rocker he informed me that there was a broken rocker before he continued so I told him to fix it and continue the original job
  #6
Old 01-13-2018, 07:17 PM
webb06's Avatar
Colonel
Member's Gallery
Default
So they came off for lifters after finding the rocker was the issue?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
