F^3 Concrete
My 2003 F250 decided to go AWOL for a few days after the front track bar bracket sheared off the axle and spring perch. From what I understand, the factory weld wasn't terrifically strong and so the crack started in the weld and then tore through the bracket. Does anyone have any suggestions for welding it back up, or does anyone know of a spring perch that can be bolted on the the axle housing? Also, how critical is an adjustable track bar.
FWIW My truck is bone stock and has 450k with the original leaf springs.
I'll try to post pics later.
