2008 F350 210,000 miles. Stock.
It is leaking about a quart of coolant whenever it is shut off hot from the passenger side of the engine. The entire engine is dry on top and even underneath, except that coolant collects on a bolt head on the front of the passenger side head and then drips down onto the cross member.
The bolt is on the head itself. It is above the lower radiator hose outlet and the horizontal EGR cooler.
I can't figure out where the coolant is coming from to get on that bolt head. There doesn't seem to be anything with coolant near the bolt head. I don't want to risk pulling everything apart and not being able to find the source of the coolant.
The closest things to the bolt head are the oil cooler and filter module assembly and the engine front cover assembly.
Both EGR coolers seem dry. None of the radiator hoses seem to be leaking. There is no obvious leakage on the coolant pump.
Any idea where the coolant is coming from ?
Thanks
Thanks
