Go Back   PowerStrokeArmy > Power Strokes > 94-97 Tech
Reply
Thread Tools Display Modes
  #1
Old 05-12-2019, 09:38 PM
clayholz clayholz is offline
Private
Member's Gallery
Default OBS Bench Seat to Captain's Chairs questions
Hey all, I recently scooped up a set of captain's chairs and center console from an extended cab f150 from the junkyard. I have a crew cab with the bench seat/flip console currently in my truck. Upon inspection I noticed that the bench uses two bolts per side and the seats are bolted to a pan. The captain's chairs each use 4 bolts to secure it to the floor. So my first question is has anyone else done this swap? It's looking like the two existing bolts/holes are going to line up with the new seats, but i believe that I will have to drill two new holes per side for the captains seats. I'm wondering if drilling new holes and using large washers would suffice in supporting the seats. I've seen elsewhere people talking about using a pan from an extended cab, but the truck i pulled the seats from didn't have a pan, there were bolted directly to the floor.
  #2
Old 05-12-2019, 10:25 PM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default
I think single cab/crew cabs are the same, and extended cabs are a different mounting style. The single/crew cans use a floor pan. Can't speak for sure on the extended cabs.
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2018 Ram 5500 Mechanics Truck
2001Tdi Jetta 5 speed
  #3
Old 05-14-2019, 12:25 AM
DarcyB DarcyB is offline
Corporal
Member's Gallery
Default
Single cab and crew cabs are the same as previously mentioned and will directly swap whether you're using bench or 40/20/40 seats. Extended cab mounts are different but doable with fabrication
Sent from my XP7700 using Tapatalk
__________________
2015 F250 SCLB, 6.7L, No Limit Fab Cold Air Intake
1978 Honda CB750K 836cc, rc gears, ikon shocks, racetech springs
1981 Bronco, 351M, 4spd
1996 F150 2wd, 300ci, M5OD
  #4
Old 05-14-2019, 12:37 AM
Private
Member's Gallery
Default
Any idea what kind of fabrication is involved? Looks to me that I would need to drill two new holes per seat on the inside, and the outside bolts would be retained from the 40/20/40
  #5
Old 05-14-2019, 09:34 PM
Corporal
Member's Gallery
Default
Not 100% sure to be honest, would have to do a search on what other guys have done
__________________
  #6
Old 05-16-2019, 12:31 AM
gnxtc2's Avatar
gnxtc2 gnxtc2 is offline
Major
Member's Gallery
Default
Don't know if you can, but can you swap over the seat tracks? I can't see Ford making a different seat for the different configuration cabs. Tracks - yes, seat - no.
Billy T.
gnxtc2@aol.com
__________________
'97 Black F250HD SC, 3.55s, Punisher Trans, PI Converter, Dana 60 RSK w/ V & C SD springs, PIS 175/80s, T500, Cale's tunes, 910s, Smith Bros, ARPs, Fluidampr, IC, E-Fuel, 3" Plenums, CJC Traction blocks, HFHV IDM, T4/BASB, Horton, 268K
- 2016 F350 DRW Ultimate (stock for now )
- 1987 Buick Grand National (Staged)
- 2004 Mercury Marauder
- 1993 Geo Prizm (beater)
  #7
Old 05-16-2019, 07:06 AM
Strokersace's Avatar
Strokersace Strokersace is offline
Colonel
Member's Gallery
Default
Quote:
Billy T.
gnxtc2@aol.com
40/20/40 Seats are the same between rc, sc, and cc. A sc seat can be removed from its track and mounted to the 40/20/40 framework and vice versa. This may go for the captains chair option from the sc too, but I havenít messed with them at all.
However the wildcard is the bench seat. On the bench, the mounting is integrated into the seat itself verses having a framework like the 40/20/40 bolt to. So I donít believe it has anything under it that you can bolt a 40/20/40 seat to.
__________________
I'm sweatin' like a wh*re in church here!
  #8
Old 05-16-2019, 10:19 AM
Private
Member's Gallery
Default
Y'all are right and i dont know how I overlooked the tracks. Started working on it last night and they swap over perfectly. I also had to swap over the recliner levers from the 40/20/40 seats. There are already 3 pre-drilled holes in the seat pan for the center console as well since the lightnings came with the captains/console configuration. I appreciate the input
  #9
Old 05-16-2019, 02:31 PM
Bugman's Avatar
Bugman Bugman is offline
Major
Member's Gallery
Default
Perhaps the OP needs to clarify a little.
Do you have a bench seat or do you have the 40/20/40 seats? In the first post you mention that it is a bench and then in another it sounds like you have 40/20/40 seats.
__________________
96 F250 4x4 XLT, 5 speed, 4:10 rear end, gauges, Dale's HX hose, Dale's Tymar, downpipe, coolant filter, add a leaf, Luc clutch
  #10
Old 05-16-2019, 02:42 PM
Colonel
Member's Gallery
Default
This! Iím confused now more than ever!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
