Go Back   PowerStrokeArmy > Power Strokes > 6.4 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 12-06-2017, 08:53 PM
Jsexton's Avatar
Jsexton Jsexton is offline
Sergeant
Member's Gallery
Exclamation 6.4 WHAT INJECTORS/NOZZLES TO GET....
My truck is a 6.4 with dual fulers with a 467.7 turbo...
Tuned by GH. The motor has your typical mods done fass, fuel bowl ******, stage 1 cam, HD valves springs, max force piston, ported manifold, pushrods all the basic stuff. Here has been my biggest issue.
The current injectors are stock with 30% NOZZLES. 85k on injectors, they have never been tested.
It's always has injector rattle but at 1845 RPM THE rattle just comes alive is is crazy loud. But after the truck build boost it goes away.
I want to put in new injectors with nozzles to match this set up. Will this cure the crazy rattle.
Also who's injector and nozzle do y'all recommend.
Thanks.
  #2
Old 12-07-2017, 05:57 AM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
in my opinion, switching to 60s would help your setup bigly power wise, as 30s are barely overcoming the parasitic loss of the second pump that it takes to drive them. I also had injector rattle with that tuning around that rpm range but it didnt really bother me. After the second motor build i found out that the rocker arms were actually causing a lot of what i perceived as injector noise fwiw.
i would suggest Exergy for any injector work.
  #3
Old 12-07-2017, 07:10 PM
Jsexton's Avatar
Sergeant
Member's Gallery
Default
Bump
  #4
Old 12-21-2017, 08:16 AM
Black AOD's Avatar
Black AOD Black AOD is offline
Colonel
Member's Gallery
Default
Exergy wont touch 6.4 injectors. They only ever did about 3 sets ever and then they quit doing them.
As someone else said, contact RCD.
__________________
08' F350 6.4L EC/LB - Built Motor, Midwest Diesel 5R, Elite 2.0 High Powers, Twin Pumps with 100%s... 11.8 @ 116, 850/1602 - GONE
2017 F350 CCLB Platinum SRW - Lowered, King 2.5" Resi's, PTM & Tint
U.S. Army 11B / 2010-2014
  #5
Old 12-07-2017, 07:32 PM
ncollins64's Avatar
ncollins64 ncollins64 is offline
Colonel
Member's Gallery
Default
Send your injectors to River City Diesel and have them flowed and tested. I’d go with 60s or 100s and have GH tune accordingly. Exergy is another good choice but maybe a bit more money.
__________________
•2013 F350 CCSB PLATINUM
•08 F-350 CCSB 950/1493
Midwest Diesel, Elite Diesel, RCD, OUO, No Limit Fab, PMF Fab
•1997 F-350 7.3, srw, rclb, 4wd, 5speed (work truck)
•Past rig: 2000 F-350 ccsb, 1100 hp 6.7 cummins
  #6
Old 12-08-2017, 11:52 AM
Jonnydime's Avatar
Jonnydime Jonnydime is offline
Major
Member's Gallery
Default
I will have a set of balanced 60% injectors for sale in the next month or so.
  #7
Old 12-08-2017, 12:21 PM
Corb@CorbinShipping's Avatar
Corb@CorbinShipping Corb@CorbinShipping is offline
Sponsor
Member's Gallery
Default
Quote:
How much you looking to get out of them?
__________________
Corbin Shipping, LLC.
Autryville, NC
(910) 578-4960 Call/text for quotes
Corbin.shipping@gmail.com
Veteran owned, Veteran operated
2013 F350 CCLB DRW 75mm Add a turbo <FOR SALE>
2010 F250, Harley Edition. getting closer...
2017 F350 CCLB DRW Platinum Ultimate...
2008 RCLB XL, Short bed conversion about to begin...
SDRCM # 1691
  #8
Old 12-08-2017, 12:30 PM
Jonnydime's Avatar
Major
Member's Gallery
Default
If someone had a set of low mileage stockers that they would send to rcd to be checked and flowed I would do an even trade.
  #9
Old 12-08-2017, 04:19 PM
Lipka101 Lipka101 is offline
Lieutenant
Member's Gallery
Default 6.4 WHAT INJECTORS/NOZZLES TO GET....
What’s low mile for you? I have a set with 153k. Original injectors and fuel system.
Sent from my iPhone using Tapatalk Pro
  #10
Old 12-16-2017, 10:59 AM
AirFishAutomotive's Avatar
AirFishAutomotive AirFishAutomotive is offline
Colonel
Member's Gallery
Default
I have a set of 150% Mpd nozzles with injectors (3 inj need to be redone) 800 for them all
__________________
AIR FISH AUTOMOTIVE
POWERSTROKE PARTS * SALES * SERVICE
LAUREL, DELAWARE
302-875-2818
www.AIRFISHAUTOMOTIVE.com
FACEBOOK.COM/AIRFISHAUTOMOTIVE <--NEW
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
