6.0 performance parts
slc dzl
Riverton, Utah
Have a few parts that i will not be using.
430/250 elite diesel hybrid injectors.
have a less than 5 hours run time on them, the last time they were used was in deranged.
WILL REQUIRE DUAL HPOP.
$1500 W/cores $1800 without.
Absolute apex ported manifold.
slightly warped, requires spreading during install.
$600
Absolute billet coolant filter $200
Mpd t-4 stainless up pipes $700.
slc dzl
Riverton, Utah
Means exactly what it says.
When the manifolds are cut and rewelded the heat and recooling process caused slight contraction of the far end "leg" of the manifold About 1/16th.
The spreading is push the legs apart while bolting it in place.
As for absolute use the search function.
Harleyx
T ville
Lol why wouldn't they weld them attached to a set of heads so they don't warp...welding 101
