Missing and loss of power. 01 f250 automatic
kingbilly68
Hey guys, Got a new issue. Rough idle. Not romping. Misses on acceleration with a cel. Drive for 30 minutes or so and it clears up usually. Only way I can pull codes is torque app and it shows no codes. No unusual or excessive smoke. Any advice is appreciated. Had it scanned at Oreilly and auto zone and it showed no codes other than air bag indicator and left front speed sensor. No long starts and it does this regardless of temperature. It’s been anywhere from 32-80 degrees here lately.
DieselDC
They can’t scan it correctly. Your scanner is probably for fitting. Find a buddy with ae scanner.
Idm most likely.
Valve cover gaskets
Wiring etc
Injectors themselves.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
kingbilly68
Idm most likely.
Valve cover gaskets
Wiring etc
—————signature—————
I’ll see if I can find someone near me with ae. If not, hopefully a local shop has a snap on scanner.
kingbilly68
Got it scanned today. Idm code. Anything I should check before I order one?
DieselDC
Order that first. Ebay. Cheap. I got two of them.
—————signature—————
kingbilly68
Order that first. Ebay. Cheap. I got two of them. I found refurbished for $129 with lifetime warranty.
—————signature—————
Any reason to go with higher voltage with stock injectors?
DieselDC
They are all the same whether it be from an obs or Sd. The 120v is more efficient so get that.
—————signature—————
kingbilly68
These are after replacing the idm. I buzz tested today and #7 was very weak.
kingbilly68
It was the harness. It was partially unplugged inside the valve cover. 50 cent mod...
