Go Back   PowerStrokeArmy > Premium Vendors > Sunrise Ford Parts
Reply
Thread Tools Display Modes
  #5101
Old 11-04-2019, 02:51 PM
Motostroker's Avatar
Motostroker Motostroker is offline
Major
Member's Gallery
Default
Quote:
Originally Posted by sunrisefordparts View Post
The tube is going to be part of the vac reservoir, see attachments...
thanks,
Sean
Let’s get all of that on the way, except for the one clamp listed.
Drake946@gmail.com
Sent from my iPhone using Tapatalk Pro
  #5102
Old 11-04-2019, 03:28 PM
sunrisefordparts's Avatar
sunrisefordparts sunrisefordparts is offline
General
Member's Gallery
Default
Quote:
Drake946@gmail.com
sounds good, I emailed you the quote...
thanks!
__________________
Sunrise Ford Parts
http://www.sunrisefordparts.com
to order:
pm us your email address & quote #
or call (909)441-3940
or paypal: payfont@sunriseford.com please reference quote number
  #5103
Old 11-08-2019, 01:12 PM
buckeye7048's Avatar
buckeye7048 buckeye7048 is offline
Private
Member's Gallery
Default
APIM for a 19 f150 to add nav to our xlt with the factory 8” touch screen.
Thanks,
George
  #5104
Old 11-08-2019, 02:38 PM
General
Member's Gallery
Default
Quote:
Thanks,
George
Hi George,
I can only get APIMs on a per VIN / exchange basis, I have no way of ordering an upgraded unit....
sorry,
Sean
__________________
Sunrise Ford Parts
to order:
  #5105
Old 11-10-2019, 01:15 PM
Justinlw Justinlw is offline
Corporal
Member's Gallery
Default
Hi, looking for a couple things for a 2010 F250 6.4l:
Rear Bump Stops Right and Left
Large hose from Fuel Fill Neck to Tank
Front Lower Coil Spring Perch Bolts
  #5106
Old 11-11-2019, 09:37 AM
General
Member's Gallery
Default
Can I get the last 8 digits of your vin please
thanks,
Sean
__________________
Sunrise Ford Parts
to order:
  #5107
Old 11-11-2019, 10:46 AM
Corporal
Member's Gallery
Default
thanks,
Sean
AEB02377
  #5108
Old 11-11-2019, 10:55 AM
General
Member's Gallery
Default
AEB02377
Rear Bump Stops Right and Left: List $49.82 -- your cost $34.37 each
Large hose from Fuel Fill Neck to Tank(serviced with filler neck assy only)
:List $262.72 -- your cost $173.39
Front Lower Coil Spring Perch Bolts (serviced with lower spring mount only)
: List $57.77 -- your cost $39.86
thanks,
Sean
q589314
__________________
Sunrise Ford Parts
to order:
  #5109
Old 11-15-2019, 07:21 PM
longstroker42 longstroker42 is offline
Private
Member's Gallery
Default
vin- 1FT8x3BT4BEC09402
can i get a price on both left and right cylinder heads, primary water pump, secondary water pump, fuel injector return line, serpentine belt and rear blocks with ubolts
d.yankowski3@gmail.com
  #5110
Old 11-15-2019, 07:45 PM
General
Member's Gallery
Default
Hi,
The heads are updated, they are going to require different glow plugs. I went ahead and added the glow plugs as well as head gaskets and head bolts to the ticket as well as nuts for the Ubolts...
quote 590001 is attached (shipping will be extra)
thanks,
Sean
__________________
Sunrise Ford Parts
to order:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Designed by Military Ltd
