Go Back   PowerStrokeArmy > Power Strokes > 94-97 Tech
Reply
Thread Tools Display Modes
  #1
Old 01-10-2018, 08:53 PM
Lgobs Lgobs is offline
Private
Member's Gallery
Default 96 powerstroke no start
My truck will not start it cranks good and blows white smoke but just sits there and cranks. I replaced the glow plug relay but still no start.
I know its bad for it but i give it a shot of of ether and it fires right up and runs fine. It will even start after being shutoff once it is warmed up.
Not sure where to go from here any help will be appreciated.
Sent from my SM-G892A using Tapatalk
  #2
Old 01-10-2018, 09:23 PM
superpsd's Avatar
superpsd superpsd is offline
Major
Member's Gallery
Default
If it's white smoke highly likely getting fuel. I would first ohm out the glow plugs. Likely your plugs are burnt out. Stick to motor craft plugs. Aftermarket plugs tend to swell creating a heck of a massive problem.
__________________
2020 F450 STX CCLB 4x4
1997 F250 TVS Supercharged, S369, R&D IDI T4 mount, my 350/200s, Honey Badger SR, my tuning, bmw m3 seats, RSK TTB, Toyo M/T
1948 GMC pickup Detroit 453T
1951 Mack A51T
1916 Federal 1 1/2 Ton
  #3
Old 01-10-2018, 09:27 PM
Bugman's Avatar
Bugman Bugman is offline
Major
Member's Gallery
Default
^^^^^ This
Test the glow plugs from the valve cover gaskets. The outside pins on each connector go to the plugs. I don't remember what the readings are for a good plug but I believe it is between 2 and 6 ohms.
You might do a search to find out for sure. Also only Motorcraft ZD-11 glow plugs for replacement.
__________________
96 F250 4x4 XLT, 5 speed, 4:10 rear end, gauges, Dale's HX hose, Dale's Tymar, downpipe, coolant filter, add a leaf, Luc clutch
  #4
Old 01-11-2018, 06:29 AM
jschildm's Avatar
jschildm jschildm is offline
Sergeant
Member's Gallery
Default
This is a good article on testing the glow plug system. This is for an SD, so the valve cover gasket plug is different, but the rest of the system is the same. As Bugman said, its the outside pins on each valve cover gasket plug that go to the glow plugs. The article has the acceptable resistance range, I thought it was like 0.8 1.2 ohms or something.
http://powerstrokearmy.com/forums/sh...ad.php?t=11563
__________________
1997 F350 CCLB, 3" DP to 5" Straight Pipe, DIY Intake, 6.0 Tranny Cooler,Adrenaline, Irate Electric Fuel, Matt's Tunes and SD Seats ... IC and H2E sitting in the garage.
  #5
Old 01-11-2018, 12:14 PM
Chris2590's Avatar
Chris2590 Chris2590 is offline
Sergeant
Member's Gallery
Default
Replace your glow plugs like they’re saying ^
It’s not a hard job on an OBS
  #6
Old 01-11-2018, 08:12 PM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default
Unless you're in super cold weather, a 7.3 will start without glow plugs. Not sure where you're at. You could plug the block heater in overnight, and see if it starts then. My guess, unless you're up north in some stupid cold, is that your problem is elsewhere.
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2018 Ram 5500 Mechanics Truck
2001Tdi Jetta 5 speed
  #7
Old 01-11-2018, 08:17 PM
Private
Member's Gallery
Default
Thanks glow plugs sound right to me.
Its been pretty cold lately in montana here thanks for the help
  #8
Old 01-11-2018, 09:49 PM
Bugman's Avatar
Major
Member's Gallery
Default
Quote:
Me thinks that you need to move a little bit north of the Mason Dixon Line.
Even in the summer my truck needs the glow plugs to start, that is unless it is above 70 for half the day. But then perhaps it will but I don't want to wear my batteries and starter down to where it might start when it is below 70.
__________________
  #9
Old 01-11-2018, 10:28 PM
dsberman94's Avatar
dsberman94 dsberman94 is offline
General
Member's Gallery
Default
Motorcraft zd-11 plugs are $74 on eBay right now. Just bought a set myself.
__________________
02 F250 7.3 Crew Cab Short Bed Lariat
PHP Hydra, Ge4rhead tunes, Edge insight CTS monitor
Mild Trans Build, Dual disc TC
GTP38R, T500, PIS 175/80s in the engine. waiting to see rods one day
Turned 200k miles 1/18/2015
  #10
Old 01-12-2018, 12:01 AM
blacksmoke.r.us's Avatar
blacksmoke.r.us blacksmoke.r.us is offline
Sergeant
Member's Gallery
Default
I changed a set of glow plugs recently on a friends truck and it helped but still had a hard time starting.
Then I replaced the under valve cover gaskets and it would then start like new.
I would suggest changing the uvcg's as well if you are already in there.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
