Can I fit 37s?
Ice Cream Sammich
2016 F250
Front: Carli 2.5" coils and 1.5" Icon spacers
Rear: Carli Deaver leafs, no block.
Sits perfectly level. Currently running 295/65R20 tires, wanting to give 37x12.50R20 a shot next go around. I think a local tire shop will let me test fit, but I haven't asked yet.
What do yall say?
erbear28
Pennsylvania
Depends on what offset and width wheel you want to run. You can on stocks but you'll rub the radius arm at full lock
Ice Cream Sammich
My apologies, I meant to state, I am indeed running stockers.
Not opposed to wheel spacers, but love not to.
Ice Cream Sammich
Yeah, if you dont mind.
I wasnt planning on upgrading to a 3 link, but will if it guarantees no rub and better ride.
Won't change the ride a spec. What it will do is give you the ability to centre your axle in the fender and adjust your alingment correctly. Plus will avoid rubbing issues on 12.5 wide tires for sure. Can't speak for 13.5
Phydough
Rutherfordton, NC
This adjustability is huge as you go to larger tires. The ability to adjust castor will help combat the "death wobble" that many suffer from. Before I went 4 link on the front I dreaded hitting bridges as I would get the wobble. After proper castor adjustments afforded by the 4-link I now dont ever have to worry about it.
TrickTruck
Simpsonville, SC
37" ridge grappler on 22" wheels w/ a +10 offset.
I would definitely like to get the PMF blocks that center up the rear and their 3 link and move that front axle a smidge forward too.
Tuner and diet first though. Getting really tired of 11mpg.
No diet yet? Dafuq you waiting for?
