Go Back   PowerStrokeArmy > Non - Specific > Project Forum
Reply
Thread Tools Display Modes
  #221
Old 10-08-2018, 03:43 PM
Lubbockguy1979's Avatar
Lubbockguy1979 Lubbockguy1979 is offline
Major
Member's Gallery
Default
Just curious.... why not body swap and carry over as much of the interior as humanlu possible. Dash, hvac etc? A few years back the laughable show power block did a body swap similar to yours using a dodge 2wd cummins dually. They reused alot of the donor stuff. Ibassume it would speed up and help the swap. Just a idea. Being a avid fan of the late 70s fords ive kept a tab on this
Sent from my SM-G955U using Tapatalk
__________________
RANDY
2006 F250 CCSB 6.0 PSDFX4 LARIAT
SCTX2 CUSTOM TUNES, ISSPRO FUEL,AIR, FIRE,AND TRANNY
PRETTY MUCH STOCK
  #222
Old 10-08-2018, 06:05 PM
gwunter's Avatar
gwunter gwunter is offline
Lieutenant
Member's Gallery
Default
Your wiring issue is a simple fix. Just do a modest mechanical conversion on the 7.3 and with one 12v wire you will be up and running......and breaking everything behind the engine back on the drivetrain. Lol
Sent from my SAMSUNG-SM-G900A using Tapatalk
__________________
Just a crazy, wannabe machinist....making crazy stroker parts.
  #223
Old 10-09-2018, 09:49 AM
1killerz's Avatar
1killerz 1killerz is offline
Sergeant
Member's Gallery
Default
Two main reasons:
1. I wanted something different than the body swap or the cummins transplant. The thought of keeping the frame, body, and all else that I could 1970's was the driving force.
2. I'm stoopid and love painting myself in a corner. if I had body swapped, kept gasoline, or even "gasp" went the cummins route, I'd been driving her a long time ago.
I remember seeing that episode of Power Block, hoping to get some insight. The insight is I am doing it the long and hard way.
__________________
If it was easy, everybody would have done it.
  #224
Old 10-09-2018, 09:53 AM
1killerz's Avatar
Sergeant
Member's Gallery
Default
All I have seen is some not so modest stuff like this:
https://www.gohypermax.com/productdi...c-8df2dccc5adb
__________________
  #225
Old 11-18-2018, 08:31 PM
BrandonMag's Avatar
BrandonMag BrandonMag is offline
Private
Member's Gallery
Default
Super cool build!
I have also had diesel projects that took way longer than originally intended... or that I never finished. What you've done so far looks great! Just keep pecking away at it, eventually you'll get there.
__________________
2008 Ford F-450 44 King Ranch (minor mods)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
