5r110. 2wd
Lipka101
Maryland
Long story short I built my transmission and the pump went out immediately after, bought this one used so I could drive my truck til I got it fixed.
Came out of a wrecked 2wd 2008 5.4l w/81k on it. Has 6.0 style pan. I tore it down and put a diesel low/reverse clutch and snap ring and suncoast “wide load” direct clutch. Everything looked fine minus the direct clutch which is why I put the suncoast in.
I put 5k on it without a problem and just pulled it and put my built one back in.
Fluid is drained because I needed the pan and extension housing. No guarantees, included your choice of 6 or 8 stud converter,
$500 Will not ship unless buyer arranges and pays for it.
Sent from my iPhone using Tapatalk Pro
Lipka101
Maryland
FYI. This can be changed to 4x4 by swapping the output shaft and extension housing from your existing trans.
Lipka101
Maryland
No longer for sale. I pulled the pump today and saw the overdrive clutches are toast...
