Links Ive found useful over the years
Austin, Tx
Here's a bunch I posted on another site just to add to the info in the thread. Looks like some of the links didn't work. I will fix them later.
Steve Baz’s page:
Tips - Idea - Hints
6637 intake:
http://www.ford-trucks.com/forums/95...iy-intake.html
http://www.midnightmods.com/2010/01/6637-mod.html
3” Downpipe install:
How to: Downpipe Install - PowerStrokeNation
2wd to 4wd conversion:
http://www.ford-trucks.com/forums/95...ng-d-50-a.html
Accelerator Pedal Fix:
http://www.ford-trucks.com/forums/10...-makomark.html
Clear headlight installs:
http://www.ford-trucks.com/forums/98...s-install.html
http://www.ford-trucks.com/forums/10...s-of-pics.html
HID conversion:
Fixing common fuel system leak points:
http://www.ford-trucks.com/forums/80...-write-up.html
http://www.ford-trucks.com/forums/98...eak-fixes.html
Rear disc brakes:
http://www.ford-trucks.com/forums/63...-are-here.html
http://www.ford-trucks.com/forums/99...ion-2-0-a.html
HPOP replacement:
http://www.ford-trucks.com/forums/53...-part-1-a.html
TikiWiki : HPOP R & R
Turbo removal:
TikiWiki : Turbo removal 1994.5-1997 PowerStrokes
GPR bypass:
Performance Injectors for 7.3L Ford Power Strokes
38 gallon rear tank:
Fuel tank vent mod:
http://www.ford-trucks.com/forums/96...-mod-redo.html
10k mod:
TikiWiki : 10 K Mod
http://www.ford-trucks.com/forums/65...on-my-10k.html
http://www.midnightmods.com/2009/09/...version-1.html
SD fuel heater upgrade:
TikiWiki : 94-97 PSD Fuel Heater Upgrade
Injector replacement:
TikiWiki : 94 through 97 Injector R&R
How To: 7.3L Powerstroke Injector Removal and Installation
http://www.ford-trucks.com/forums/93...r-install.html
FPR shim:
TikiWiki : Shim Your Fuel Pressure Regulator 94-97
Traction bars:
Multifunction switch replacement:
http://www.ford-trucks.com/forums/10...ml#post9952744
Intercooler installs:
1996 Ford F350 4x2 - Intercooler
Ford OBS (1994-1997) powerstroke intercooler instal - Great Lakes 4x4. The largest offroad forum in the Midwest
http://www.ford-trucks.com/forums/95...ll-pt-1-a.html
Tims I/C Page example
Oil Cooler R&R:
http://www.ford-trucks.com/forums/90...-write-up.html
http://www.ford-trucks.com/forums/33...placement.html
Oil Cooler How To...since it's that time of year. - PowerStrokeNation
Transmission Cooler upgrade:
http://www.ford-trucks.com/forums/86...ed-w-pics.html
Transmission Cooler Installation - PowerStrokeNation
Dipstick tube seal replacement: IN TRUCK
http://www.ford-trucks.com/forums/78...-be-fixed.html
Dipstick Tube Seal Replacement - PowerStrokeNation
Gauge install:
Gauge Install
http://www.thedieselstop.com/faq/949...ks/gauges.php3
Electric fuel:
http://www.ford-trucks.com/forums/94...el-system.html
Electric Fuel Conversion - PowerStrokeNation
Electric fuel system conversion - PowerStrokeNation
ZF5 short throw shift kit install:
Midnight Mods: MidWest Trans Short Throw Shifter Kit Install for ZF5
Chip installation:
http://www.totaldieselperformance.co...stall94-97.pdf
York onboard air:
http://www.ford-trucks.com/forums/85...ally-here.html
Hydroboost conversion:
http://www.ford-trucks.com/forums/98...onversion.html
Converting EBPV to an exhaust brake:
http://www.ford-trucks.com/forums/60...-write-up.html
Converting gas truck to 7.3L PSD:
http://www.ford-trucks.com/forums/94...p-started.html
Converting XL to power windows/locks:
http://www.ford-trucks.com/forums/10...-xlt-swap.html
Adding cruise control:
http://www.ford-trucks.com/forums/10...e-control.html
Common no start issues:
http://www.ford-trucks.com/forums/97...tart-list.html
Clutch rod end bushing repair using heim joint off Ebay:
http://www.ford-trucks.com/forums/80...shing-fix.html
Replacing pedal box bushings:
http://www.ford-trucks.com/forums/98...pic-heavy.html
Sterling 10.25" info:
http://www.fourwheeler.com/techartic...ips/index.html
Ford axle code chart:
http://www.ford-trucks.com/article/i...de_Chart_.html
DIY Auxilary idle controller(AIC):
http://northtexaspowerstrokes.com/mods/aic/
http://www.ford-trucks.com/forums/1020339-diy-aic.html
Upgraded headlight harness:
http://www.northtexaspowerstrokes.co...pgradeharness/
http://www.ford-trucks.com/article/i...r_Brights.html
140v IDM:
http://www.ford-trucks.com/forums/82...-140-volt.html
