farmall16
I just bought a 1997 F-Super Duty with a 7.3L and ZF5. It has the transmission mounted parking brake. The truck had the transmission out of it when i bought it because the mainshaft was snapped off. I found a transmission for it and was making sure I had everything I needed. It’s missing the transmission crossmember. It has the brackets on the frame. I have a 4x4 ZF5 crossmember but it doesn’t fit. I thought it would fit because it’s a 4x4 transmission with the parking brake bolted to it. Can I use a 2WD ZF5 crossmember from a F250/F350 or is there a specific F-Super Duty crossmember?
