Go Back   PowerStrokeArmy > Power Strokes > 7.3 Tech
Reply
Thread Tools Display Modes
  #21
Old 06-29-2018, 09:10 AM
lariat 7.3 lariat 7.3 is offline
Lieutenant
Member's Gallery
Default
Did it again today. Stumbled gauges kinda flickered And check engine light and wait to start illuminated. Felt like it died, switched to N and it fired back up. OD switch doesn't work could I know the wire shorts could that cause this
Sent from my SM-G935V using Tapatalk
__________________
2000 F250 ccsb 4x4. 297k miles, Leveled 05 coil spring swap on 20x12 35's, 364.5 SXE CSD T4, 238/80% FFD hybrids,T500, Full sinister RR stainless with bowl removed and Dual Bosch pumps. GH tunes on Hydra, BTS DIESELSITE Boots, Autometer C2 series gauges, DIY tymar, remote start. 08 mirrors. dual Fox Resi Shocks
  #22
Old 06-29-2018, 03:26 PM
6.0 Tech's Avatar
6.0 Tech 6.0 Tech is offline
Colonel
Member's Gallery
Default
The icp sensor circuit low code is most likely your issue.check for oil in the icp connector. If there is oil there, change the pigtail as well, cleaning it doesnt work 90% of the time.
__________________
04 cclb IDP and TSD tunes, KC Stage 2 hi pressure, S476 atmosphere, Odawg Stage 2 ported intake, RCD Stage 1 cam, RCD lifters and pushrods, RCD 120# valve springs, ARP 625s, o ringed heads, Warren 7mm 250/100 hybrids, Strictly bowl dereete regulated return, Air Dog 2 4g, Snow stage 2 water/meth
  #23
Old 06-29-2018, 05:11 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Quote:
Originally Posted by fastersteve View Post
Every time I've seen multiple non sensible codes like that, it's been low volts due to a dead alternator or battery.
This is exactly what i was thinking. Monitor voltage while driving.
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #24
Old 06-29-2018, 05:14 PM
Lieutenant
Member's Gallery
Default
Voltage has always been 13.5+. Oil in Connector. Been driving all day without it connected been good so far
__________________
  #25
Old 06-29-2018, 08:52 PM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
If you get another one you better get a name brand one. It’ll be like $125 or so. RiffRaff sells them.
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, S471, Beans IDM, ARP head & main, girdle, half filled block, DI cam, Dual IPRs, ceramic coated bowls, anti-friction skirts, Haldex pump over Stock pump, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #26
Old 06-30-2018, 05:37 AM
ju015dd's Avatar
ju015dd ju015dd is offline
Sergeant
Member's Gallery
Default
Quote:
Originally Posted by Magnum PD View Post
If you get another one you better get a name brand one. Itíll be like $125 or so. RiffRaff sells them.
Yes. Do not buy the cheap ones. They do not ever work right.
__________________
2000 Ford F250 Powerstroke 4x4 c/c 6speed, 278k on truck and 207k on 96 engine all cylinders blew 400 psi, ARP head studs, melling lpop, comp springs shimmed, smith brother push rods, 238/100% Hybrids by Rosewood, 38r/ww2, fluiddamper, Strictly Diesel Reg Return, Strictly Diesel post and pre fuel filters, AFE - Straight Piped, Hydra with ******** @ PHP tunes, Srp 1.1, hutch @ harpoon mod, !
  #27
Old 07-03-2018, 07:50 AM
General
Member's Gallery
Default
Voltage should stay 14+ after warmup.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
