Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #141
Old 10-09-2019, 09:21 AM
fastersteve fastersteve is offline
Sergeant
Member's Gallery
Default
Quote:
Originally Posted by superpsd View Post
Not sure about Dave but Johnathan looks like he opened a new buisness focused on PCM repair/flashing and other electronics.
Got a name or contact info for that business?
__________________
2001 Excursion LTD
AIS, 4" MBRP, SRP 1.1, ******** Tunes, HD4R100, 38R with a Turbomaster. Bigger injectors on the way
Family race car hauler
  #142
Old 10-09-2019, 11:52 AM
trevdalocal trevdalocal is offline
Private
Member's Gallery
Default
Quote:
https://www.dieseltechchatt.com/pages/about-d-t-c
__________________
'96 XLT CCLB ZF5 4WD - Strictly Diesel Efuel w/RR and SD pump, Irate T4 w/366 SX-E, PIS 250/200, PHP Hydra w/GH Tuning, Stage 1 Organic SB, 4" Magnaflow no muffler, 4.10s on 35s
  #143
Old 10-09-2019, 06:52 PM
powerlifter405's Avatar
powerlifter405 powerlifter405 is offline
Major
Member's Gallery
Default
Had no idea, thanks.
Dave helped me trouble shoot some issues over the phone years ago. Was GTG.
__________________
05 original factory head gaskets, ARPs @ 302k torqued@ 250ftlbs, Redhead steering gear KC 63.5mm... factory stuff, rancho 9K's adj, 6.7 starter upgrade
  #144
Old 10-10-2019, 09:03 AM
Sergeant
Member's Gallery
Default
Quote:
Originally Posted by trevdalocal View Post
Thank you!
__________________
2001 Excursion LTD
  #145
Old 10-13-2019, 08:17 PM
KCTurbos KCTurbos is offline
Major
Member's Gallery
Default
Quote:
Originally Posted by Swaan View Post
That's great , glad you can do some testing.
Too bad you couldn't do it all on the same dyno in the same day. As we all know air quality and altitude play huge roles in numbers. Looking forward to see some results.
Actually... that is why dyno's have "corrected numbers". Because you can't keep all variables exactly the same even 1-2hrs apart.
The "corrected numbers" take into account temp, altitude, humidity, etc... all the variables that change. It uses a fancy formula to "give and take" as needed to keep the baselines the same. It is pretty accurate from all of our testing. Just last week we took a truck that we had on the dyno 8 months ago when it was much cooler out, swapped around turbos a bunch of times, and went back to the original testing turbo. We are about to test something other than turbos and wanted to make sure our baseline was still correct... but who knows what can happen with a truck that is beat on over 8 months and did not want to throw off the data. So we put the original turbo testing turbo and went back to the dyno this week... EXACT SAME power curve and within 2 hp (which is negligible and can vary more than that just between dyno runs).
Long story short... that is why we use "corrected numbers" for all of our testing because it keeps a baseline and allows us to test things all year round and not have to worry about having he "exact same conditions".
Granted that is also why sometimes "corrected numbers" don't align 100% with track numbers.
I know this goes contrary to popular "internet" belief... but Dyno's are much better for testing products back to back because they can take these variables into account. They can also monitor and catch much smaller details.
  #146
Old 10-17-2019, 11:15 PM
cjfarm111 cjfarm111 is offline
Lieutenant
Member's Gallery
Default
It’s been a month and a half and still no testing? Results? Seat of pants difference?
  #147
Old 10-18-2019, 10:03 AM
jbolen323's Avatar
jbolen323 jbolen323 is offline
Sergeant
Member's Gallery
Default
ran into a motor issue hiccup on my end that im tearing into that is affecting a lot of things along with sending off my injectors to be gone through. started dumping blue smoke after a hit on the dyno again.
I can barely crack 500hp on 350/200 and a s472 when all of my other trucks here are low 500hp on 238/80
ill keep everyone updated.
__________________
2002 FFD 350c/200%| t4 w S472sxe| Termy Twins | SDK/JELIBUILT/GH/PHP tunes| BTS Race Trans 2400 stall | 6.4 conversion
e99 Tow pig FFD 205cc/30% | t4 w BASB Bell turbo |SDK/ JELIBUILT/GH/PHP tunes | adrenaline hpop| John Woods Race trans|340k|
2012 6.7 King Ranch, KC 15+ Whistler Turbo, MPD goodies, Ez Lynk w/ TSD
Sales @ KC Turbos
  #148
Old 10-18-2019, 10:19 PM
Lieutenant
Member's Gallery
Default
Oh ouch. What seems to be the issue
  #149
Old 10-19-2019, 05:27 PM
Swaan's Avatar
Swaan Swaan is offline
Lieutenant
Member's Gallery
Default
Prob the new oil rail restrictions . Lmao
Sorry couldn't resist.
Hope you get it figured out and she's not hurt too bad.
__________________
E97 f250 ECLB. SOLD!
Dana 60 front with rsk kit. 5" blocks in rear. 4:10 on 35s. Blackwater reman 7.3 with arp studs , comp springs. 175/80 pis inj, adrenalin hpop,irate fuel system with fuel lab pump. Borg warner 364.5 fmw with 1.00 a/r housing. EC450 horton electric fan clutch. ZF5 shaker.
--16 f350 ccsb lariat 6.7 tuned and D-leted!!😈
--15 VW passatt TDI sport. Tuned and D leted 6 speed
  #150
Old 10-22-2019, 07:36 PM
superpsd's Avatar
superpsd superpsd is offline
Major
Member's Gallery
Default
If it's like half the parts that come to market for the 7.3 no unbiased controlled tests will ever reveal if the new restrictor tubes work.
__________________
2020 F450 STX CCLB 4x4
1997 F250 TVS Supercharged, S369, R&D IDI T4 mount, my 350/200s, Honey Badger SR, my tuning, bmw m3 seats, RSK TTB, Toyo M/T
1948 GMC pickup Detroit 453T
1951 Mack A51T
1916 Federal 1 1/2 Ton
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
