2018 F250 ford OEM cab light Harness Part Number
g2outfitter
So I have a 2018 f250 that had Recon lights on when I purchased, well 4 of the lights have gone out so I installed all new Recon lights and non are working. I spent about 3 hours trying to diagnose the problem and found that installer ran harness down A pillar driver side to a splice then runs under dash, through firewall and ties into marker light of headlight. At the A pillar spice I have about 2.5 volts and at the plugs I have nothing. So I am assuming the recon harness has crapped out and shorted some where.
Long story short I want to replace recon harness with factory OEM and plug into passenger side A pillar. Does anyone know the part number. I have researched with no luck.
Thanks
Coy
Sent from my SM-G965U using Tapatalk
drh4250
Eldon, MO
Might just message Sunrise Ford in their thread of what you're looking for. They're pretty quick and helpful.
g2outfitter
I sent them a msg last night, havent heard anything back but maybe because the weekend.
