PVXCummins
Finally in the process of pulling the 6.0 from my 04 to do a rebuild on the engine. Obviously during the process I had to remove the 6 Torque Converter nuts.
My question is what is the easiest way to remove said nuts? I removed the rubber grommet from the adapter on the block to access the bolts. It was a pain in the a$$ to sneak a 14mm socket, with a 1" extension in with a ratchet. Then i could only back the nut off half way to then smack the ratchet with a hammer to remove it because it was wedged against the oil pan, and then finish removing the nut by squeezing my fingers up in to back it off the rest of the way. I guess I am used to my 12 Valve which has an access cover on the side of the adapter plate which you can easily access and remove the converter nuts.
Is there a special socket, or tool that i can use when it comes time for the re-install? I just can't fathom that 'by the book' is bottoming a ratchet against the oil pan and smacking it out with a hammer.
