Will running the engine with the transmission wiring unplugged damage it?
Master_Chase
South Houston
Odd question will the transmission be damage if the engine is running and it's not receiving power, for example, the transmission connections are unplugged, the starter is stuck on, engine run away, etc?
Thanks in advance
Mesa, AZ
It shouldnt. Withput anything plugged in, you will need to start it with the key on and using the jumper wire on the fender. It will not crank, as it doesn't know what gear its in.
