Go Back   PowerStrokeArmy > Power Strokes > 6.4 Aftermarket
Reply
Thread Tools Display Modes
  #21
Old 02-11-2018, 10:38 AM
Strokersace's Avatar
Strokersace Strokersace is offline
Colonel
Member's Gallery
Default
I know it sounds crazy, but on our two 6.4s, I removed the 4” mufflered systems in favor of a 5" with the same Donaldson muffler Mike is using because that setup is MUCH quieter and no drone!
On the one truck, the 4" flopro with muffler was bearable but still too loud. The other truck was a 4" flopro straight pipe. The drone was horrible with this setup.
Both trucks have a 4" 2 piece down pipe and the 5" on back with the big Donaldson muffler. Quiet, no drone, but still sounds aggressive when you want it to.
I've contemplated adding a resonator to get it whisper quiet, but haven't felt the need to yet.
Both trucks are cclb's.
__________________
I'm sweatin' like a wh*re in church here!
  #22
Old 02-11-2018, 10:43 AM
mikeeg02 mikeeg02 is offline
Lieutenant
Member's Gallery
Default
I had an initial exhaust whistle I didnt care for with the FTE, then I added that donaldson, and it amplified the whistle, and drone was still prominent. Now the ONLY thing I have is that 5" muffler. Truck is quiet inside and out. No obnoxious sounds, no drone. Closest thing to stock I have ever used. I have had it on for about a year now. Aside from single shots, the truck is nearly stock sounding from in the cab.
__________________
285k+ for miles, 238/100s for fuel, T500 for oil, 366sxe for air, ge@rhead for tuning, DRW for towing and myself for shifting gears. Pushrods, beehive springs, arp studs... trying to quit........
  #23
Old 02-11-2018, 09:57 PM
Justinlw Justinlw is offline
Corporal
Member's Gallery
Default
Just saw your reply. I’m looking up the 5” Donaldson now, hopefully that will kill the noise in the cab. I don’t feel the need to completely kill the exterior noise, but I will be a little quieter than you with the 4” Cat installed. Hopefully I can get the new muffler on next weekend and be ready for summer trips.
If it takes stepping up to 5”, I would have to do it after the cat. I’m not spending another $350 for a 5” cat. I tow a camper with the truck and my Dad has emphysema. Swears he can smell the exhaust in the camper when we get to deer camp. The Magnaflow cat kills the smell.
  #24
Old 02-12-2018, 07:29 AM
Lieutenant
Member's Gallery
Default
If you use the adapters.you can stick with 4". Mines still 4". I welded the adapters on the muffler.
__________________
  #25
Old 02-12-2018, 10:52 AM
HS-MotorsportsZane's Avatar
HS-MotorsportsZane HS-MotorsportsZane is offline
Sponsor
Member's Gallery
Default
I had the the MBRP 4" system with their muffler and our SX-E 64mm single kit on mine. I didn't mind it at all, was very quiet in the cab......
  #26
Old 02-12-2018, 11:01 AM
Corporal
Member's Gallery
Default
Quote:
I ordered the mbrp 4” with muffler this weekend, hoping that one does it. The kit that’s on now is pretty thin, and the hangers aren’t really “hanging” like they should. May be contributing to the drone.
  #27
Old 02-12-2018, 09:39 PM
6.0 Tech's Avatar
6.0 Tech 6.0 Tech is offline
Colonel
Member's Gallery
Default
Ok, stupid question here, but just ran into it today on a customers truck. He had excessive "drone" which was a lower pitched buzzing noise. He showed it to me, and turned out it was the vacuum pump running, which inside did kinda drone. It was a quieter type deal though, could only hear it with the radio off.
It aint something like that, is it?
__________________
04 cclb IDP and TSD tunes, KC Stage 2 hi pressure, S476 atmosphere, Odawg Stage 2 ported intake, RCD Stage 1 cam, RCD lifters and pushrods, RCD 120# valve springs, ARP 625s, o ringed heads, Warren 7mm 250/100 hybrids, Strictly bowl dereete regulated return, Air Dog 2 4g, Snow stage 2 water/meth
  #28
Old 02-13-2018, 10:52 AM
Sponsor
Member's Gallery
Default
Quote:
I've found that not enough, or poor hangers can contribute to that......
  #29
Old 02-13-2018, 10:59 AM
Jonnydime's Avatar
Jonnydime Jonnydime is offline
Major
Member's Gallery
Default
I added the factory vibration dampener back to get rid of my drone.
  #30
Old 02-13-2018, 03:48 PM
Jsexton's Avatar
Jsexton Jsexton is offline
Sergeant
Member's Gallery
Default
What is that part.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
