Go Back   PowerStrokeArmy > The Bunker > General Discussion Forum
Reply
Thread Tools Display Modes
  #1
Old 02-12-2018, 12:50 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default Door code question
Just wondering if anyone knows how to go about getting the factory door code for a 2015 escape that my girlfriend bought that didn't have the card in it that tells you the door code?
live life full throttle
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #2
Old 02-12-2018, 12:55 PM
DieselJpower's Avatar
DieselJpower DieselJpower is offline
Lieutenant
Member's Gallery
Default
https://youtu.be/rtFi2V1DjLk
It's for a 14 exploder, but worth a check
__________________
Josh
02 CCSB F350 4x4
04 Excursion 4x4
05 Excursion 4x4
  #3
Old 02-12-2018, 02:25 PM
eng53ine's Avatar
eng53ine eng53ine is offline
Lieutenant
Member's Gallery
http://www.explorerforum.com/forums/...orking.418723/
There's a module above the ebrake with the numbers on it according to this. I just got a 2011 and I can't get to work
Reread your question for an Escape, might be the same.
__________________
02 F-250, 7.3, auto, ccsb, 4x4, 4'' duals, 6637, IH bellowed up pipes, RiffRaff billet wheel, canned 6 pos. TS
  #4
Old 02-12-2018, 08:50 PM
6.0 Tech's Avatar
6.0 Tech 6.0 Tech is offline
Major
Member's Gallery
Default
You could take it to the dealer and have them pull it as well, or anyone with ids. Forscan may do it too, never used it, but seems like it does a lot of cool ****
__________________
04 cclb IDP and TSD tunes, KC Stage 2 hi pressure, S476 atmosphere, Odawg Stage 2 ported intake, RCD Stage 1 cam, RCD lifters and pushrods, RCD 120# valve springs, ARP 625s, o ringed heads, Warren 7mm 250/100 hybrids, Strictly bowl dereete regulated return, Air Dog 2 4g, Snow stage 2 water/meth
  #5
Old 02-13-2018, 02:54 AM
C2tuck's Avatar
C2tuck C2tuck is offline
Lieutenant
Member's Gallery
Default
I think forscan will do it...saw something about that when I was playing with mine
__________________
2015 CCSB F250 XLT FX4...stock...for now...
  #6
Old 02-13-2018, 05:25 AM
General
Member's Gallery
Default
Thanks for the link. I looked under dash but everything is covered by the sound deadening fiber carpet stuff.
Thank you. Like mentioned, its covered up i would have to tare it apart to find it. F-that.. Lol
Quote:
I dont like to take anything to the dealer. Thats why I asked on here to see if anyone else had an idea. I have forscan. Not familiar with all the escape options. Ill have to look into it more and hook it up to it.
Quote:
Ill dig into it more and see. Thanks for the reply.
__________________
  #7
Old 02-13-2018, 10:06 AM
eng53ine's Avatar
Lieutenant
Member's Gallery
Default
https://youtu.be/t4cD2_BHJDc
Good luck.
__________________
  #8
Old 02-13-2018, 09:45 PM
bigrpowr's Avatar
bigrpowr bigrpowr is offline
<How I Fly
Member's Gallery
Default
just find any shop with IDS .. easy .
__________________
Tyrant , PIP , Alberta Speed , S P A R T A N and H&S Tuners Available
6.7 5" Custom Cold Air Intakes Available
H&S Motorsports Authorized Retailer
1-800-581-8986
Click the banner below for all things No Limit Diesel
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
