Go Back   PowerStrokeArmy > Power Strokes > 2017+ 6.7 Aluminum Super Duty
Reply
Thread Tools Display Modes
  #21
Old 01-13-2018, 06:48 PM
Glassman504 Glassman504 is offline
Sergeant
Member's Gallery
Default
Hahah yes it slams. It shakes my steering wheel but itís clean thatís what I like the most.
  #22
Old 01-14-2018, 02:28 PM
HD F250's Avatar
HD F250 HD F250 is offline
Major
Member's Gallery
Default
Quote:
Originally Posted by Quigs4u View Post
Slick looking truck man!!
It looks angry!!
You can always add the subs later if you want more BOOM!!
Thanks man!
Quote:
I have a 17. With jl processor audio frog in the doors, jl amps and 2 12s jl subs. But I may change to some sd3s. Also have soundskinz everywhere. Really clean
I have heard good things about audio frog as well. Thanks for the feedback also. I agree that you truck must hit hard as hell.
__________________
2008 HD F250, Elite Stage 1 motor, High Powers, MPD 100's, dual pumps, Stage 4 trans, No Limit pipes
2008 ECSB F250, Elite Stroker motor, big nozzles and big turbos
  #23
Old 01-22-2018, 06:35 AM
HD F250's Avatar
Major
Member's Gallery
Default
Gentlemen, what did you all do with the dash center channel? Any pics? Is it one or two speakers?
__________________
  #24
Old 01-23-2018, 05:03 AM
Quigs4u's Avatar
Quigs4u Quigs4u is offline
Sergeant
Member's Gallery
Default
Quote:
My center channel is gone.
I removed it. You canít run the center channel without a processor and Iím not running a processor so itís been removed.
  #25
Old 01-26-2018, 04:08 PM
HD F250's Avatar
Major
Member's Gallery
Default
Thanks, I will probably remove it as well.
__________________
  #26
Old 01-30-2018, 01:51 PM
Kreep Kreep is offline
Private
Member's Gallery
Default
I am looking upgrade my stereo using the factory nav head unit and have a few questions for the audio guys.
1. Anyone figured out a solution to add amps to the factory head unit? I want a good clean signal because I am going with some high end components (Focal, Hertz or Morel probably).
2. Any recommendations on which speakers to use for the dash? My quick research revealed that it is two 3 inch speakers.
3. My truck is a regular cab so looking for a recommendation on a nice small enclosure sub.
1. It depends on if you have Sony or not. If you have Sony, the PAC unit mentioned earlier or the iDatalink Maestro AR canfeed an amp such as the Kenwood XR600-6DSP. My truck has Nav but not Sony so these are not an option. Instead, the hot ticket is to use FORScan to reprogram the head unit (ACM) which will result in a perfectly clean, flat, balanced output. Throw in a Parrot for-11ck wiring harness and you are in business. A word of caution if you are planning to just feed high level inputs to new amps. In either case the factory does some significant signal modification. Also, the ACM has resistance sensing. Without a speaker (or amp with high impedance inputs) hooked up it sends the chimes and such to the IPC instead and you can't hear them with the stereo playing...
2. The center channel would only be used if you care how it sounds in the passenger seat. It is a 3.5" speaker but looks to me like a 4" would fit. The real problem here is that there aren't at lot of signal processors that can properly upmix the center channel. JBL MS8 (with Logic 7) and Alpine PXA-H800 (Dolby Pro Logic) are the only two currently available (L + R and L - R solutions don't count). However, the MS8 is discontinued (available on Ebay for ~$425) and the $750 PXA-H800 requires the use of the $300 RUX-C800 single DIN controller (or certain Alpine head units). There are rumors of options from Audio Frog, Zapco and Arc but nothing available currently.
  #27
Old 01-31-2018, 01:36 PM
HD F250's Avatar
Major
Member's Gallery
Default
Thanks for the input. Now I need to find out if I have the Sony unit or not. I have purchased a few used Zapco Z-LX series amps to start and will definitely be using a DSP. As for center channel, I probably wonít use it since itís hard to make good use of it. I will keep everyone posted.
__________________
  #28
Old 02-21-2018, 12:57 PM
Tricon Tricon is offline
Private
Member's Gallery
Default
I installed some Infinity Kappa Perfect 600's in the front, Polk DBs in the rear for fill, and 2x10" Infinity Subs behind the rear seat. 200wx2 rms to the front and 400wx2 to the subs...holy moly this is one of my favorite installs. I was hesitant to go with the Kappa Perfects as the last go around they had really bright tweets. Seems like they listened this time, they sound amazing and I can turn it all the way up to 100% volume with 0 distortion or clipping. Super happy with these.
I completely gutted the interior and sound deadened the cab, then did some Mass Loaded Vinyl on the doors. The cab is dead quite inside while driving down the freeway. Its really odd being in this huge diesel monster and not hearing **** going down the road.
I didnt have the Sony system, just Sync and the 7 speakers. I ran high level signals to my amps directly and the sound floor is amazing. There's zero distortion, hisses, pops, etc. Just really clean and really loud.
  #29
Old 02-21-2018, 01:00 PM
HD F250's Avatar
Major
Member's Gallery
Default
Sounds like a nice install. I donít have the Sony either, just Nav and Sync 3. I havenít bought speakers yet, but I have some high end Zapcoís ready to push some sound soon. Thanks for feedback!
__________________
  #30
Old 02-25-2018, 09:17 AM
COPowerStroke04 COPowerStroke04 is offline
Private
Member's Gallery
Default Recent upgrades to my system
I put Focal KRX2's in the front and KR2's in the rear with a 13.5" JL Sub behind the seats with 2 amps. This thing screams. For converting sound from the stock head unit, I am using the JL Fix-86 which gives good clean sound and will probably be adding the TWK by JL as well.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
