4400 springs
Jomax
Arizona
you didn't specify which morning...clever
Lol, sorry. Left that day on a backpacking trip down the Grand Canyon. With all the craziness before the trip. Totally forgot. I'll measure it today.
Jomax
Arizona
Jomax- can you measure the distance from the center of your wheel hub straight up to the wheel arch in the fender?
I'm 22.25" front and rear. Curious where the 4400# springs measure.
I'm at 23 3/4in front and rear
MorganM
SE Houston
Ha! Thanks.
I expected to be lower, but not by this much. The first springs I tried were .5" lower than these!!
I've had this setup since 2013, and it's a bit rough at times. I think I could go back to stock shackles and 4400 springs to fix the harshness, but I'm not sure about the swaybars. I have hellwig front and back and the back one is for for a 2wd- need to call and verify fitment.
Or sell the truck. Really like new raptor.
Jomax
Arizona
Ha! Thanks.
I'm running a rear swaybar made for a 2wd.
Is your truck 2wd?
MorganM
SE Houston
Is your truck 2wd?
No- 4wd. There are signs of the bar rubbing the spare, but I think it only happens when a load is connected.
The 2wd bar will probably work at factory ride height.
Jomax
Arizona
How did you get yours so low? I'd go lower if I could. But if probably loose way to much front travel.
MorganM
SE Houston
Had springs made by Coil Spring Specialties. The first set were 3" drop with factory rate. Too low.
This set are 2.5" drop at 15% stiffer rate.
Jomax
Arizona
How much front travel do you have?
MorganM
SE Houston
~1.5 - 2". Difficult to measure it, but probably right in the middle- 1.75".
Certainly not enough to air it out over speed bumps!
Jomax
Arizona
Yeah. I'd die with that little of travel.
OryC
What size u-bolts did y'all use when removing the rear block?
andrewtac
I ordered new ones, didn’t realize they were the same as the ones on there until I was committed to the removal and the factory ones barely worked. If doing it again I’d get shorter ones.
Jomax
Arizona
I got u bolts for a 2wd without overloads from ford.
OryC
Awesome, thanks. I plan on making the switch pretty soon so wanted to make sure I had everything before I had it torn down and got stuck
OryC
Well, after lots of questioning I finally got the new suspension put on in time for Christmas! Went with 20x10 wheels with 305/50 Toyo Proxes tires and gotta say I love the way it came out! Thanks to everyone who took time to answer any questions I had and look forward to doing much more to it in the future
Jomax
Arizona
Nice! I didn’t know toyo still make the original proxes
OryC
Thanks!
Not sure, I have a parts distributor that carries them and they had them in stock so I got them. Don't like the new proxes so was pretty happy they had the originals still
97stoker350
south central pa
I'm gonna bring this back up. Sorry if I missed it but has anyone kept the rear stock with 4400# coils in the front? Mine is beginning to sag a hair in the back and I dont wanna take the rear block out because I think that would be too low... im on stock tires rn but my 22x12s and 305x45 420s should be here in a week or so. Thanks
