Go Back   PowerStrokeArmy > Power Strokes > 6.0 Tech
Reply
Thread Tools Display Modes
  #1
Old 12-11-2018, 09:10 PM
Rockin Jester Rockin Jester is offline
Private
Member's Gallery
Default Another crank no start
I'm working on a 6.0 in a 2004 e350 ford van. I do not have access to a scan gauge or programer. I do however have torque pro and pretty much able to monitor all my sensors and read codes.
The van broke down and was towed to my shop. Initial test showed icp and egr codes. I changed out the icp and it started. At times it would run fine other times not so much.
Further examination verified the egr soaken wet. Ended up replacing the heater core, egr ****** and oil cooler. Put it all back together and I've got a crank no start.
That started almost a week ago. I've been trying to figure it out since and still have the same results.
2 codes keep coming back. P2289 and 02623. Ive replaced
The icp,and the ipr. They return after 3 cranking cycles.
I tested the wiring and pigtails for resistance and voltage from the plug to plug. They passed. I swapped out my ficm and pcm from my f250 and had no change.
Cranking.
Ive got ficm sync.
48 ficm volts.
12.6 volts.
55 psi fuel pressure.
But real high hpop. 1560
@ 67% ipr.
Any ideas/thoughts ask away.
Thanks for the help.
  #2
Old 12-12-2018, 09:25 AM
Jtreece's Avatar
Jtreece Jtreece is offline
Sergeant
Member's Gallery
Default
Whats the LPOP pressure? pull the oil filter cap, remove cap and filter, push the release down in the bottom of the housing and have someone crank it. If it doesn't fill with oil then it might be the low pressure oil pump.
__________________
04 F350 CCLW SRW, 35's, CM skirted flatbed, Diablo T1000, SCT3, Studded, *******, 4", Stage 2 Tranny, blue spring, wicked wheel, loves to eat Hondas.
  #3
Old 12-12-2018, 09:11 PM
webb06's Avatar
webb06 webb06 is offline
Colonel
Member's Gallery
Default
Cranking.
Ive got ficm sync.
48 ficm volts.
12.6 volts.
@ 67% ipr.
So you have sync and ficm sync?
Icp is reading 1560psi during cranking?
Ipr is maxing at 67% during cranking?
Is the new icp sensor from ford?
  #4
webb06's Avatar
Colonel
Member's Gallery
Default
Quote:
Kinda hard to do that on an e series
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
