Go Back   PowerStrokeArmy > Power Strokes > 2017+ 6.7 Aluminum Super Duty
Reply
Thread Tools Display Modes
  #1
Old 12-01-2017, 06:31 AM
6.7w0rkhors3 6.7w0rkhors3 is offline
Private
Member's Gallery
Default ‘17 F 350 bucking when towing
Ive been having this issue for a while now. The truck has 87,000 miles and now is starting to buck violently when towing. I have a 5th wheel set up and a 3 car hauler.
It seems to do it on even a slight incline but only when rpms are low, if I smash the gas pedal is gone. Any idea you guys might have an idea what this could be? Thanks
Sent from my iPhone using Tapatalk Pro
  #2
Old 12-01-2017, 06:53 AM
DockRocker's Avatar
DockRocker DockRocker is offline
Private
Member's Gallery
Default
Sounds trailer related to me. Have you checked your hitch? Axle alignment?
  #3
Old 12-01-2017, 10:07 AM
Private
Member's Gallery
Default
Quote:
Not i have not but why would it happen and certain low rpm and only uphill. Also, it recently started happening.
  #4
Old 12-01-2017, 11:26 AM
Dzchey21's Avatar
Dzchey21 Dzchey21 is offline
Super Moderator
Member's Gallery
Default
is the truck stock?
DO you have a way to monitor things like rail pressure?
__________________
2017 F-350 DRW Platinum stock for now
1979 F-150 6.0 Swap in progress, 86mm LP turbo, 04 frame and interior
  #5
Old 12-01-2017, 10:09 PM
Private
Member's Gallery
Default
Quote:
Originally Posted by Dzchey21 View Post
is the truck stock?
Is completely stock. No way of tracking anything nor do I know what to look for. I hope you can elaborate, im new to the big diesel world.
  #6
Old 12-06-2017, 08:29 PM
ToddP ToddP is offline
Private
Member's Gallery
Default
Torque converter is locking and unlocking at low speeds. I’be never had it happen on a stock truck but in some high power 6.4l tunes it would do when when towing a lite load. It would buck violently
  #7
Old 12-06-2017, 08:32 PM
Private
Member's Gallery
Default
Quote:
So any idea how this could be fixed ?
  #8
Old 12-06-2017, 08:35 PM
Private
Member's Gallery
Default
When I had the issue on my 6.4 the advice I was given was to stop feathering in the throttle and be a little more aggressive. And it worked just had to drive it different than I usually do. But on a bone stock truck, I’d say it might be on its way out.
  #9
Old 12-07-2017, 01:35 AM
Jomax's Avatar
Jomax Jomax is offline
General
Member's Gallery
Default
You still have some warranty left. Take it in.
__________________
2017 F-250 KR CCSB 4x4- 4400 coils, rear block removal, 20x10 novakanes, nitto 420s, king shocks, OUO traction bars, 5in Alum Driveshaft.
  #10
Old 12-07-2017, 01:45 PM
Private
Member's Gallery
Default
Quote:
They have no idea what it could be, i have taken it and nothing.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
