Go Back   PowerStrokeArmy > Power Strokes > 2017+ 6.7 Aluminum Super Duty
Reply
Thread Tools Display Modes
  #101
Old 12-06-2017, 07:41 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Quote:
Originally Posted by Black AOD View Post
Here's mine currently. Driver and passenger side.
yup, now i know i definitely need new shocks. i bottom out on one bump everyday on my way to the shop. stock hight 2012 f350. but only above 65 mph.
live life full throttle
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #102
Old 12-07-2017, 05:15 AM
kubotaorange76 kubotaorange76 is offline
Sergeant
Member's Gallery
Default
Thank you for the pics. You can damn sure see the difference.
__________________
2017 6.7 Ford CCLB 4x4 37's
2017 F-150 CCSB 4x4 5.0 XL
1989 F-150 RCLB 2x4 4.9/c6/2.73 DD
1979 F-150 RCSB 4x4 400/c6/205
  #103
Old 12-13-2017, 07:39 PM
redracer62's Avatar
redracer62 redracer62 is offline
Sergeant
Member's Gallery
Default
Decided to reverse level this truck. Got new U-bolts in today. Thanks Jomax for getting me the right part #. Will get the blocks out and get the rear dropped on Saturday. Will just have to figure out shocks after this. Think I might try some 2.5" shocks to see what all the fuss about them is.
By chance do you remember what you torqued the ubolts to? I知 gonna do mine soon
__________________
2017 F350 platinum Fx4
  #104
Old 12-13-2017, 07:41 PM
Black AOD's Avatar
Black AOD Black AOD is offline
Colonel
Member's Gallery
Default
Quote:
I think 175 ft-lbs. FYI those ones you quoted are for F250 with rear block removal and NO top overload. I had to return those and get different ones because I have a 350 with top overloads.
__________________
08' F350 6.4L EC/LB - Built Motor, Midwest Diesel 5R, Elite 2.0 High Powers, Twin Pumps with 100%s... 11.8 @ 116, 850/1602 - GONE
2017 F350 CCLB Platinum SRW - Lowered, King 2.5" Resi's, PTM & Tint
U.S. Army 11B / 2010-2014
  #105
Old 12-13-2017, 07:52 PM
redracer62's Avatar
Sergeant
Member's Gallery
Default
Ok thanks! I’m doing mine a little different than yours. I was mainly curious what you torqued them to. Truck looks good btw!
__________________
  #106
Old 12-13-2017, 08:13 PM
Black AOD's Avatar
Colonel
Member's Gallery
Default
Ok thanks! I知 doing mine a little different than yours. I was mainly curious what you torqued them to. Truck looks good btw!
No problem. And thank you! What's the plan for yours?
__________________
  #107
Old 12-14-2017, 07:36 AM
redracer62's Avatar
Sergeant
Member's Gallery
Default
Mines leveled on 35痴 now. The back is still a little high for me so I知 getting some blocks off a dually I think. There like an inch shorter than mine now so it should be better looking after. Then I値l get some real shocks after that.
__________________
  #108
Old 12-14-2017, 05:54 PM
bluedge8's Avatar
bluedge8 bluedge8 is offline
Colonel
Member's Gallery
Default
Double check that torque spec, sounds high. What size is that bolt?
__________________
'96 f350 cc lb 4x4, 6637, auto, 264k Pretty much stock
'03 chev 2500 crew cab duramax 395k bone stock
'02 F350 dually, Lariat, auto, banks everything, hydra on the way.
Quote:
Originally Posted by Arisley View Post
D3leted 6.0's are the best. D3lete them and replace with a Cummings.
  #109
Old 12-14-2017, 05:59 PM
Black AOD's Avatar
Colonel
Member's Gallery
Default
Factory are 5/8
__________________
  #110
Old 12-14-2017, 07:40 PM
redracer62's Avatar
Sergeant
Member's Gallery
Default
I know this says 2015 but it looks good to me(found through google)
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
