I think most people are worried about the durability of the Walbro being used with diesel fuel. I have ran one on my OBS for three years now without issue. The key is to pre-filter and run red fuel. I have also sold a few hundred with only a couple warranty claims (yes I will warranty it once and recommend a better pre filtration set up).
Technically you can't run red fuel unless its for off road use only, just saying by law, and not everyone has access to it, but what filters do you recommend? Cause I need a set for backup cause its not like I can pick filters up anywhere
A good 10-15 micron filter will do the trick! And you would be surprised how many people use the "red" fuel, we see it all the time in core injectors!!
