ISO complete set of 2006-2011 f350 axles
NY_Mott
The Real "OC" NY
Looking for matching front and rear axle combo for a jeep project.
From what I'm told it should be a Dana 60 front and Dana 80 rear. (Don't want the 10.25)
Will end up swapping gears so that does not matter much.
Just need from caliper to caliper.
Thanks.
NY_Mott
The Real "OC" NY
Why 06 on up? For coil fronts?
I really can not give all the answers as I do not have them... but I have a 94 f350 ball joint axle and the production numbers vs the newer axle is way low and aftermarket support sucks. I'm building a 1 ton rock crawler and just want to make sure I'm getting a good axle..
A member on her pmd me and I'm going to order the set from him...
