Go Back   PowerStrokeArmy > Power Strokes > 6.7 Tech
Reply
Thread Tools Display Modes
  #101
Old 01-11-2017, 12:14 AM
Jomax's Avatar
Jomax Jomax is offline
General
Member's Gallery
Default
Quote:
Originally Posted by Dieseljay74 View Post
Let us know...hopefully this is a solid fix for everyone with this annoying issue
Sent from my SM-G930T using Tapatalk
Didn't change the filter, but I did try to drain it while running and nothing changed for me.
__________________
2015 F-250 6.7 CCSB Lariat, B&W gooseneck, no limit shiny stuff, GH/AS tuned, H&S intercooler pipe Upgrade, MBRP DPEF back dual exhaust, S&B intake, edge CTS2.
13.2sec 1/4mi @100mph
  #102
Old 01-11-2017, 08:57 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is online now
General
Member's Gallery
Default
how long do all of you guys let your lpfp run before you start the truck?
live life full throttle
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #103
Old 01-12-2017, 09:32 AM
Jomax's Avatar
General
Member's Gallery
Default
When changing the filter?
__________________
  #104
Old 01-12-2017, 09:49 AM
04cr450's Avatar
04cr450 04cr450 is offline
Major
Member's Gallery
Default
The book says operate a koeo cycle 7 times? My truck is quiet under the hood only hearing the typical diesel sound.. something wrong for sure, I have also been around a hand full of 6.7'S and none of them sounded strange like this
__________________
2016 f250 Platinum tri-coat white, 22x12 AF satin black traxx with 325/50 terra g2, no limit goodies, flo pro exhaust, sct x4, recon smoked side and cab lights, retro solution led head and fog lights
  #105
Old 01-12-2017, 10:20 AM
General
Member's Gallery
Default
Quote:
anytime you start it.. mine has a lil whine when I first turn the key.. I can hear/feel my lift pump gargle/prime and when that clears up and the whine goes away, I start the truck.. not sure if it matters though.. some have it.. some dont..
__________________
  #106
Old 01-12-2017, 11:42 AM
Jomax's Avatar
General
Member's Gallery
Default
Yeah I have that as well.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Designed by Military Ltd
