2003 sending unit
Knoxville,tn
My sending unit is bad, shows empty when topped off and never is accurate but gauge does still work. I'll be dropping the tank this weekend is there a fix to this problem or is it just a new sending unit
IIVonnyII
Langley, BC , Canada
if the gauge still works , and you never had the tank dropped before I would guess just a sending unit. drop the tank, if the float still looks good undamaged , replace the sending unit. test it out before you reinstall.
