Rear glass swap
slc6oh
Utah
So, knowing the cab is the same for basically all years:
Has anyone swapped the earlier (99-07) rear windows for a glue in 08+?
I have a manual rear slider with some decal staining from previous owner, and im getting tired of the imprint of the elk head on my back window and also not a fan of the slider in favor of solid glass (just looks better imo)
Anyone done it?
Sommers
Should have left the elk sticker would go great with the camo seat cover and steering wheel cover you have
ckrueg
Belding MI
I actually think that is one of the differences between cabs. If you look at the glass for pre 08 truck it's different than 08+
03shorty
Maryland
You could just swap it for a solid piece and keep the gasket. If you do the 08 you may have that line from where the gasket was or a little residue, depending on vehicle/paint condition.
When I had mine repainted I went with the 08, I agree they look cleaner.
03shorty
Maryland
slc6oh
Utah
So the glass does fit fine? Assuming my paints good or could be cut n buffed id really rather go with the glue-in
03shorty
Maryland
Yeah fits perfect. I work for my families glass company and we've done quite a few of them. I recommend going with a carlite glass.
slc6oh
Utah
Sweet!! Thanks. Ive got a buddy that does glass so ill be getting with him for sure!
Joshf250
I know I’m bringing up an old post but I’m about to repaint my 05 and I’m really wanting to update the rear glass. Is there any special advice when putting the new window in and how do you get it centered up?
Barnbuilder
Waxhaw, NC
I did it on mine and it leaks like he'll. The pinch weld is narrower on the older trucks I believe. Also there is nothing to cover up the pinch weld at the top interior.
Joshf250
That’s good to know, thanks for the input! I’ll probably just pass on doing that for now then
