BorgWarner 4407 Front Driveshaft Leak
m_j
looks like you take the yoke off, pull the seal, replace the seal and reassemble.
if that is the only seal you need dont buy a whole kit
JCart
Thanks m_j,
Dudeamanscott, check the tech drawing, as it might be part 50 or could even be part 3 if the yoke nut is a bit loose. Reason I say this almost a year ago I did a Dana 60 swap to my sig truck and I forgot to replace the seal #3, found it after I put in the new driveshaft, thought I’d wait to see if it’d leak so far it hasn’t but the yoke is tight.
j
