Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 07-15-2019, 07:47 PM
Dscrant Dscrant is offline
Private
Member's Gallery
Default 180/100 smoke issue, tuning or need more air
I have another question that I can't find much info on. Recently fixed a crazy short causing fried IDM's (2 to be exact). Now that I finally got to drive her, I'm getting quiet a bit of smoke on my FFD 180/100 single shots.
Is this something I have to live with for full potential from these. I have 6 custom tunes ECO, TOW, DAILY, HOT, EXTREME, and DRAG. Even on ECO 1/2 to 3/4 throttle she's noticeably smokey (not just hazy)
Current upgrades GTP38R, 4" Turbo back, 6637, HPO X-over, Regulated return set to 65ish
On any tune past 3/4 throttle, it's a blackout behind me
__________________
'99 F350 180/100, GTP38R, Regulated return, Custom Tunes, 4" Turbo-back, Bellowed, Bored, and Studded
  #2
Old 07-15-2019, 08:47 PM
wildbill963258's Avatar
wildbill963258 wildbill963258 is offline
Lieutenant
Member's Gallery
Default
I'm not an expert by any means but I would say you either need some different tunes or need a bigger turbo or even check for boost leaks
__________________
'96 F250 ECLB, 2wd, Auto, DIY CAI, 3"DP for exhaust. Sadly sold
'94.5 F350 CCLB 2wd ZF5 DIY CAI 3" DP for exhaust and stock tunes for now
  #3
Old 07-15-2019, 10:25 PM
Private
Member's Gallery
Default
Ok, just finished checking. No boost leaks that I could see. All clamps are tight and boots intake, plenums look good too.
I figured that turbo would be sufficient for those injectors.
Tunes are still being adjusted. In constant contact with the tuner.
Is it possible I need to adjust the wastegate? I got the full package from Full Force Diesel, stage 2
__________________
  #4
Old 07-15-2019, 10:29 PM
lariat 7.3 lariat 7.3 is offline
Lieutenant
Member's Gallery
Default
Yes the Wastegate could be preset too low. Quick test will be to pop off the red line and go drive. See if it's better. You have the stock one? Prob need to tighten it up a few turns.
Boost gauge? What are you producing
__________________
2000 F250 ccsb 4x4. 297k miles, Leveled 05 coil spring swap on 20x12 35's, 364.5 SXE CSD T4, 238/80% FFD hybrids,T500, Full sinister RR stainless with bowl removed and Dual Bosch pumps. GH tunes on Hydra, BTS DIESELSITE Boots, Autometer C2 series gauges, DIY tymar, remote start. 08 mirrors. dual Fox Resi Shocks
  #5
Old 07-16-2019, 12:48 AM
Lieutenant
Member's Gallery
Default
I agree I forget about the wastegate because I've always had non waste gated 7.3's but yes the waste gate could be set to low. I would check that as well because that's free and easy lol
__________________
  #6
Old 07-16-2019, 07:50 AM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
A visual check for boost leaks is virtually useless. You’re going to need to pressure check the system (10-20 psi) and listen/soap check for leaks.
  #7
Old 07-16-2019, 08:16 AM
Private
Member's Gallery
Default
Yup, I'll use some snoop leak check after work. I'm getting a temp gauge setup because I haven't decided a direction for permanent gauges yet. I'll post an update after work
__________________
  #8
Old 07-16-2019, 08:19 AM
Swaan's Avatar
Swaan Swaan is offline
Lieutenant
Member's Gallery
Default
Pressure test charge air system first. If all good just unhook the red line for wastegate and see if that clears up the smoke. If it does then wastegate needs adjusting.
How much boost are you seeing wot right now? What's your egts wot??
__________________
E97 f250 ECLB. SOLD!
Dana 60 front with rsk kit. 5" blocks in rear. 4:10 on 35s. Blackwater reman 7.3 with arp studs , comp springs. 175/80 pis inj, adrenalin hpop,irate fuel system with fuel lab pump. Borg warner 364.5 fmw with 1.00 a/r housing. EC450 horton electric fan clutch. ZF5 shaker.
--16 f350 ccsb lariat 6.7 tuned and D-leted!!😈
--15 VW passatt TDI sport. Tuned and D leted 6 speed
  #9
Old 07-16-2019, 01:08 PM
jbolen323's Avatar
jbolen323 jbolen323 is offline
Sergeant
Member's Gallery
Default
honestly you are always going to have smoke and egt issues with those injectors, we really try to not even push those anymore. I ran them for 3 years with drop ins and full t4 setups and never could overcome it. Getting a improved turbo will help some, but ideally changing injectors is going to be the best option. Going with a kc300x 63/73 turbo would beneficial as well to a degree, but the problem is the 100% nozzle in my opinion.
__________________
2002 FFD 350c/200%| t4 w S472sxe| Termy Twins | SDK/JELIBUILT/GH/PHP tunes| BTS Race Trans 2400 stall | 6.4 conversion
e99 Tow pig FFD 205cc/30% | t4 w BASB Bell turbo |SDK/ JELIBUILT/GH/PHP tunes | adrenaline hpop| John Woods Race trans|340k|
2012 6.7 King Ranch, KC 15+ Whistler Turbo, MPD goodies, Ez Lynk w/ TSD
Sales @ KC Turbos
  #10
Old 07-16-2019, 03:01 PM
Private
Member's Gallery
Default
Thanks jbolen323... unfortunately all of this is brand new and I didn't research enough before purchasing. I may have to just suck it up and deal with it until I can get different injectors. I appreciate the input.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
