Go Back   PowerStrokeArmy > Power Strokes > 6.7 Tech
Reply
Thread Tools Display Modes
  #1
Old 07-15-2019, 07:02 PM
Jake Jake is offline
Major
Member's Gallery
Default Truck will not shift from Park (electrical)
Coming home today I stopped to get the mail. Put in park, now it won't come out of park, no brake lights, no "P" lit up. You can shut it off and get it shifted to neutral, start up and it's just fine with the exception of no brake lights. Brake lights do work with 4 way flashers on.
Fuse 18 good
Fuse 21 I dropped into the abyss
31 good
35 good
Any ideas?
Sent from my XT1650 using Tapatalk
__________________
2015 F350 finally joined the 21st century!
  #2
Old 07-15-2019, 08:21 PM
Major
Member's Gallery
Default
Well fuse 21 was blown, replaced and it's working now.
Does anybody have the wiring diagrams for this circuit?
When I shifted to park the P flickered then stayed solid. Well into the hunt to find this.
__________________
  #3
Old 07-17-2019, 10:06 PM
Major
Member's Gallery
Default
Nobody?
__________________
  #4
Old 07-18-2019, 05:03 PM
webb06's Avatar
webb06 webb06 is offline
Colonel
Member's Gallery
Default
First guess would be the brake switch on the brake pedal
  #5
Old 07-18-2019, 10:12 PM
Major
Member's Gallery
Default
Brake switch is good, looks like it's the switch that senses if it's in park. The truck keeps saying shift to park as it doesn't think it's in park.
__________________
  #6
Old 08-13-2019, 08:54 PM
dtarepair dtarepair is offline
Private
Member's Gallery
Default
You may wanna block the wheels crawl under and see where cable hooks on lever of trans its adjustable it may not be pushing the lever back enough, i have replace a few of these cables and ran into this issue
Sent from my SM-G960U using Tapatalk
  #7
Old 08-14-2019, 08:35 PM
Major
Member's Gallery
Default
It's the shift cable. How do you adjust it? Im going to let it cool down some and bring it in to the shop. Looks like there is a adjustment right above the linkage connector.
__________________
  #8
Old 10-22-2019, 08:40 AM
Major
Member's Gallery
Default
Update....
It was the transmission range sensor inside the transmission.
Went to unplug it, and it pulled the sensor out of the switch body.
New switch in it's all happy now.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
