diy dual feeders?
oneturboforme
just wondering if anyone has tried it... ive been thinking about doing it hardest thing would be routing the lines and getting the right size pulley..
thanks
lubeowner
Platteville, wi
thanks
Finding someone who can make the lines is harder then most think. Getting the pulley and bracket right and finding the proper 8 rib belt was hard. Now since i have posted all the pics of my setups it should be alot easier for the diy'ers to copy and do on there own. But in the end i am not sure you can do it much cheaper yourself them buying parts from me.
White_monster
The great white north
Rob at Dirty Diesel had the first twin fueler on a 6.4 that I know of. We used a stock siemons pump off a custom bracket at the crank. Works great. It's not rocket science and the twin fuelers can be built very cheaply if you have the resources at hand.
derrick36
I remember him talking about that and I think I even have some pics saved. Did everything fit with the stock fan in place or were electric fans swapped in?
Dzchey21
wyoming
And a controller that works is impossible for the average dude
oneturboforme
Would you just run the pumps in parallel? The signal would be the same for both pumps and wouod result in the same pressure right? I reqllt have no clue I'm just asking
SEABEE08FX4
Montgomery TX
If you use a factory pump from my understanding yes you can splice the electrical together and run each off the same signal. A lot less complicated from what I gathered than a CP3/Siemens combo.
Dzchey21
wyoming
Finding someone to build you lines is gunna be the toughest part finding a tee is almost impossible for the average Joe
Kind
It does work well... but it does have it's own set of issues he has yet to address. Nothing major, just prematurely wearing out one part.
Electric fans. There is no way a stock fan would work.
Dzchey21
wyoming
Holy hell thanks... I think I'm gonna try it.... Just wish I knew about the signal more but i thik I'm just gonna parallel them
Whats the worst that could happen i plow up a motor? lol
You might hurt injectors if you don't control it correctly
oneturboforme
You have a dual feeder kit right.... Is there a control box or do you just splice the connection.....
oneturboforme
I feel if its the same pump the same signal then both pumps output would be the same, just would work less to build that "output"
derrick36
Don't jump the gun on this.
Look at his response.
That would be cool.... if only they used metric lines
I'm assuming the link I posted would not work for what you're thinking of doing.
oneturboforme
I'll find someone I use to deal with swagelock I know there smaller stuff goes up to around 15k and they have heavier just not sure how high
derrick36
Swagelok does use metric stuff but it's only rated to 15k(like you said).
Their stuff that's rated to 60k is all SAE.
They don't have anything rated in the 20-55k range in metric.
