DIESEL DR DUAL FUELER QUESTION
AirFishAutomotive
DELAWARE
On the diesel dr dual fueler is there supposed to be a small spacer behind the pulley and the pump ? The pulley is hitting the bracket but unsure if thats because the tolerances are so tight and the bracket & pulley are both powdercoated.
Have tried to get up with them and they have not answered, thanks
Matt
Minnesota
Don't believe there is on mine. Mine always ran 1 rib off like the pulley needed to be spaced out though.
Groomzybanshee
St Joe mo
You need to adjust the bracket. How old is the kit? I know he had a few wheels that the offset was wrong and to close to the bracket.
AirFishAutomotive
DELAWARE
took the powdercoat off and the pulley spins fine, problem now is that the belt hits the front tensioner, even with a new tensioner so going to play with it some this weekend
AirFishAutomotive
DELAWARE
Bulldogman
Where did y’all get the cp3 bracket from. I’m looking for just the bracket I have everything else. 2013 6.7
