Can hydroboost be done w/SD axle swap?
West Virginia
My brake booster has failed and I'll be beginning my SD axle swap soon. I've read that everyone who does the hydroboost conversion likes the pedal better afterward but that it's not recommended to do with disc brakes. Any truth to this? Don't want to buy the swap parts then not be able to use them.
Bigmo
??? Most of the hydroboost set ups use disc brakes....whywould it be anything else
brewer
Not sure where you heard that. It is a great conversion to do w/ disc brakes. However, you need to get the flow-through rear valve for the master cylinder from an F-SD.
There are many great threads on this swap.
