Go Back   PowerStrokeArmy > Power Strokes > Aftermarket Super Duty 1999 - Current
Reply
Thread Tools Display Modes
  #591
Old 02-27-2015, 09:06 AM
bruce's Avatar
bruce bruce is offline
Colonel
Member's Gallery
Default
-54 offset, yeah those are gonna rub if you don't trim the front valance, prolly hit the fender and full turn also
__________________
-Bruce
On PSN they still change their hpop oil
  #592
Old 02-27-2015, 09:24 AM
dsberman94's Avatar
dsberman94 dsberman94 is online now
General
Member's Gallery
Default Wheel/Tire Tech Thread
Doesn't matter now. Lol. I was gonna get a cheap leveling kit to so I could trim as little as possible.
__________________
02 F250 7.3 Crew Cab Short Bed Lariat
PHP Hydra, Ge4rhead tunes, Edge insight CTS monitor
Mild Trans Build, Dual disc TC
GTP38R, T500, PIS 175/80s in the engine. waiting to see rods one day
Turned 200k miles 1/18/2015
  #593
Old 03-01-2015, 03:18 PM
Nathan1234 Nathan1234 is offline
Private
Member's Gallery
Default
I have a 06 f-250 6.0 and I'm wanting to run moto metal 962's 18x10 on stock height what size tire can I run without have to worry about rubbing
  #594
Old 03-01-2015, 03:35 PM
psduser1's Avatar
psduser1 psduser1 is offline
Colonel
Member's Gallery
Default
All these pictures, and no excursions.
Mine is 03, with 2 inch spring hangers, and u codes up front, back is b codes with a two inch block. I want to go with 18x9 or 10 rim. I'm looking at something like an ultra 225, or motometal 971. Tires will probably be Hankook 305/65 or so, anybody have any pics? About 95% street, it's a grocery getter, lol.
Currently have big 285/75/16, and they are done!
sorry about the sideways picture.
__________________
2000 f250 zf6, air, oil, fuel mods, flatbed dual dana 80
Almost stock
2001 f250 same setup as the 2000, auto trans
2002 with a couple of mods, grocerygetter
  #595
Old 03-05-2015, 08:43 PM
strokinpower's Avatar
strokinpower strokinpower is offline
Sergeant
Member's Gallery
Default
Well I just ordered a 4" BDS with fox shocks and 20x9 0mm offset Gear alloy big blocks with 35x12.50x20 Toyo AT2's. Looking at pics now has me concerned the wheels aren't going to stick out enough. I had 20x9 0 offsets on my 6.4 and they looked perfect to me so I hope these will too. Here is a pic of my old 6.4
__________________
Keith
2014 F250 Platinum FX4
AFE intake
  #596
Old 03-08-2015, 11:08 AM
mandkole's Avatar
mandkole mandkole is offline
Major
Member's Gallery
Default
A couple of pics with the polished 20x8s, 2" spacers and 295 60 Procomp MT2. This tire is just over 34" and is about as tight as you can get with stock height. At full lock to left, there is a slight contact with inner liner at bottom. May try to pull it back further.
__________________
2000 F250 CCSB GT4294R, 250/100s, Dahl/Fuelab, BTS, PHP tuning, stock 17* pump
1994 F250 SCLB
(sold)
1997 F250 CCSB 2wd (sold)
  #597
Old 03-09-2015, 12:02 AM
Bakwoodz's Avatar
Bakwoodz Bakwoodz is offline
Private
Member's Gallery
Default
I've got an 03 f350 4x4 and I'm looking at either doing some 18x10 or 20x10 (both fuel wheels I like have -12 offset) wrapped in 33x12.50. I'll be putting a 2.5in leveling kit up front. I don't mind a little sticking out but I want to keep trimming to a minimum. From what I have read on this thread I should be able to do either of these wheel and tire combos without rubbing. Am I correct in assuming that? Also I wouldn't be able to do a 35 without issues correct? I don't care for the stuffed wheel well look.
__________________
2003 6.0 f350 CCSB xlt. Zone 4" lift, 20x9 Mayhem Riot Wheels, 35" Toyo M/T, 4" Turbo back straight pipe exhaust, SCT tuner, edge CTS for gauges. Kenwood deck, Memphis audio door speakers, 12" P3 and 1200w amp.
  #598
Old 03-09-2015, 05:02 AM
psduser1's Avatar
Colonel
Member's Gallery
Default
Quote:
Turned out nicely
__________________
Almost stock
  #599
Old 03-09-2015, 08:59 AM
Bakwoodz's Avatar
Private
Member's Gallery
Default
I think instead of the leveling kit I'm going to run a zone offroad 4" lift, 35x12.50 R20 Toyo AT II along with 20x9 Helo 878 in satin black part # he87829087712n. It has the -12 offset, not sure on back spacing. Anyone see any problems with this set up? I'm hoping to have it ordered very soon. I'd like to install everything by the end of the month before I drive the truck from Idaho back here to Nola.
__________________
  #600
Old 03-09-2015, 01:28 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Quote:
you dont need that big of a lift to clear.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
