Go Back   PowerStrokeArmy > The Bunker > Drag Racing
Reply
Thread Tools Display Modes
  #351
Old 07-08-2017, 04:16 PM
DZL JIM DZL JIM is offline
Sponsor
Member's Gallery
Default
I'm terrible at posting pics and videos online.
That's not my car, but basically what we are talking about.
__________________
RosewoodDieselShop.com 440-286-1990, Chardon, OH.
Specialists in 7.3L Power Stroke injector restoration.
Full service and repair on all Ford Power Strokes.
DzlJim.com Some OBS DIY projects.
PSA Sponsor map!
  #352
Old 11-11-2017, 08:42 AM
Bgdiesel's Avatar
Bgdiesel Bgdiesel is offline
Private
Member's Gallery
Default
BRIAN GRAY
1996 2wd Truck 7.3 HEUI
10.52@126mph 1st pass Fuel Only, Terrible track conditions can't wait for a good track!
DRY SUMP OIL SYSTEM, signature not updated yet
__________________
'96 RCSB PIS 400/400's Single 80mm BTS Twin pump setup Dry Sump Oil System designed for HEUI by Gray's Diesel Performance. Zero balance rotating assembly 16v electrical system/electric water pump/Gray's Diesel engine mounted fuel system with Fass 220/Colt Cams stage 2/Gray's Diesel piston bowl work and ring mods/Swamps tuning
  #353
Old 11-11-2017, 02:54 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Quote:
Originally Posted by Bgdiesel View Post
BRIAN GRAY
nice pass!
live life full throttle
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #354
Old 11-11-2017, 04:42 PM
Bgdiesel's Avatar
Private
Member's Gallery
Default
Quote:
Originally Posted by lincolnlocker View Post
nice pass!
Thanks!
__________________
  #355
Old 11-11-2017, 06:10 PM
hucorey's Avatar
hucorey hucorey is offline
Sergeant
Member's Gallery
Default
Has Brian Jelich updated his time slips on here? He just made a very nice improvement with his new 4 link suspension setup.
Sent from my Pixel XL using Tapatalk
__________________
E99 CCLB 4X4 SRW F350,Billstein5100s,X-code front leafs, 35" Nitto TG's on 22" Incubus', GTP38R w/ WW2 140V Mod'd IDM, Billet intakes, AFE stg II CAI, 4" Diamond Eye T/B SS exh, BTS trans w/P.I. tc, 6.0L cooler, FF 250/200% SS's, ******** Stg I cam, CompCams 910 springs, Smith Bros HD push rods, Insight CTS, Forged bottom end, PHP Hydra, Firestone Airbags, All Amsoil fluids, Stealth 1.1 HPOP, ARP studs, My Modified Fuel System & HPOP lines, AGR steering gear
  #356
Old 11-12-2017, 12:34 PM
General
Member's Gallery
Default
doubt it.. he hasn't been on in a while..
__________________
  #357
Old 11-13-2017, 10:34 AM
imelmo's Avatar
imelmo imelmo is offline
Super Moderator
Member's Gallery
Default
BRIAN GRAY
Awesome!
__________________
The FORDOTA, '86 Toyota reg cab tube chassis to be powered by a 6.0 Powerstroke; finally back in progress
'03 F250 Reg Cab Short Bed 4x4, ZMBYKLR, 946rwlt (rear wheel llama thrust), 10.38 @ 129.60, Truck Source Diesel, Warren Diesel, Gardner Racing, Diesel Innovations
  #358
Old 11-13-2017, 03:48 PM
HOLDERDOWN's Avatar
HOLDERDOWN HOLDERDOWN is offline
Colonel
Member's Gallery
Default
elitepowerstrokes.com has all the lists
__________________
Jaran @ Holderdown
A Not Fast Enough 2006 F-250
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
