monster50iii
- Joined
- Dec 1, 2014
- Messages
- 6
- Reaction score
- 0
We tow with our 7.3, and pull a 16,500 trailer. In the summer its not uncommon to see 260-280* for oil temp. After doing reading sounds like this is 50-75* higher than normal. The truck throws a low pressure code for the high pressure oil. I am replacing the IPR(and sensor??), and ICP sensor. Now, what could cause the high oil temp? I thought maybe the sensor is bad, so I'm replacing that as well. We bought this rig 2 years ago with 130k miles on it. Could the coolant not being replaced ever (not sure, just brain storming incase it never has...we never have anyway) cause the oil cooler to plug and get this kind of heat? Whenever we are on big pulls up a hill duty cycle with be over 90%, and pressure will be below 2000psi.
