Line Out Converter and Sony System issues.
Goindownhole
Running into an issue here and I'm seeing if anyone else has ran into it.
I've been running a PAC loc on my factory sub outputs for a while but was getting annoyed that every time, without fail, it would set the amp into protect at 21 volume.
I moved the loc to the left rear speaker outputs, and have the same issue.
Voltage at the amp is fine.
I can unplug the sub and turn the volume to 21 and the amp will go into protect.
Is our factory sony signal so dirty that its sending the amp into protect?
I was trying to stay away from the 300$ harness behind the dash but it looks like its headed towards that.
