Go Back   PowerStrokeArmy > Non - Specific > Welding & Fabrication Forum
Reply
Thread Tools Display Modes
  #1
Old 10-11-2016, 03:26 PM
UpstateDieselGuy's Avatar
UpstateDieselGuy UpstateDieselGuy is offline
Lieutenant
Member's Gallery
Default Entry Level MIG Welder
My father in law gave me an oxy/acetylene torch set which got me thinking about a welder. After looking around, I'm thinking an entry level MIG would be the best for me. I'm thinking that a gas/gas less setup would be ideal. Just looking to pick some brains. Thanks, Chris
__________________
2015 F-350 Extended Cab Short Box Lariat; Tuxedo Black with Black Leather Interior; 8 1/2' Fisher MM2
  #2
Old 10-11-2016, 03:39 PM
David1089 David1089 is offline
Sergeant
Member's Gallery
Default
Fluxcore is your option for gasless and it's not ideal for much. Maybe thin mild steel. I'd suggest a system that allows the use of gas all day. It's smoother, more consistent and easier to control
__________________
2015 F2SEXY Platinum!!
  #3
Old 10-11-2016, 03:52 PM
Flounder_Pounder's Avatar
Flounder_Pounder Flounder_Pounder is offline
Sergeant
Member's Gallery
Default
Quote:
Ditto, try and save up for a 220 machine if you can. As an owner of Hobart 140....I wish I'd saved up for a 120/240v machine such as the 210 MVP
__________________
Travis T
1999.5 F350 4X4 CC LWB (mine)
2002 F250 4X2 CC SWB (wife's)
  #4
Old 10-11-2016, 03:41 PM
Skill_Kills Skill_Kills is offline
Sergeant
Member's Gallery
Default
I learned on a lincoln sp135. IIRC I liked it. had a gasless machine at home and i hate it. Now i have a hobart Ironman 230 which i love. Also ran a Miller 250 in school and liked it quite a bit as well.
If id get an entry level machine id just grab a 110v gas mig welder. flux machines are frustrating IMO
__________________
-Brian = Fulltime Farmer, Part time Welder
'53 F250
S468, 250/200s, ARP studs, COMP springs, smith bros pushrods, South Bend DD Clutch, Irate fuel, 1023tunes on hydra
02 350 CCSB 7.3L Lariat 4x4
Farm truck. homemade flatbed
  #5
Old 10-11-2016, 05:09 PM
TRUBBS's Avatar
TRUBBS TRUBBS is offline
Lieutenant
Member's Gallery
Default
i have a millermatic 211 and really like it a lot. can be done either 110/220 and will do 035 wire
__________________
Just another 6.4 on the road waiting to split a piston
  #6
Old 10-27-2016, 08:06 AM
Sterling B.'s Avatar
Sterling B. Sterling B. is offline
Sergeant
Member's Gallery
Default
Quote:
Another vote for the MM 211. I go it because I didn't have access to a 220 plug, but wanted the option to run on 220. I really wanted the 252, but without access to the power to run it, it would have been useless.
__________________
'00 F250 ECLB 4x4 315/75R16 Cooper STT Pro
F450 front and 350 DRW Springs w/ PMF front Shackles
370K miles and counting
DP Tuner: Stock, 40T, 60T, 80E; 6637 air filter
5" Flo-Pro, B&W Turnover Ball, Sinister coolant filter
ISSPRO EV2s (Pyro, Boost, Trans)
'15 F350 CCLB DRW... basically stock
  #7
Old 10-11-2016, 06:34 PM
Lieutenant
Member's Gallery
Default
Thanks for the input. So many options out there!
__________________
  #8
Old 10-11-2016, 07:15 PM
fine69's Avatar
fine69 fine69 is offline
Major
Member's Gallery
Default
I have a 200 amp, 240 volt Lincoln MIG I bought at Home Depot. It will work with or without gas, and weld steel up to 1/4" thick. I've never used it without gas, only with Argon. It works great, and I'm a newbie welder!
__________________
2009 F350 4x4 CCLB
  #9
Old 10-11-2016, 07:23 PM
89 Stroker's Avatar
89 Stroker 89 Stroker is offline
Major
Member's Gallery
Default
Any of the Miller Matic's would do you good. 100% C02 is cheap gas, gets good penetration but does not look as good as 75/25 ect.
i would arc weld before i used flux-core, unless your burning thick stuff.
Check out CyberWeld.com , they have good prices on just about everything.
__________________
-Jeremy
Got A Few Rides...
  #10
Old 10-11-2016, 07:30 PM
78f100's Avatar
78f100 78f100 is offline
Major
Member's Gallery
Default
I have a Hobart handler 190 from tractor supply, it's a great welder for the average guy. Iirc they are 800$ish
__________________
08 F250 ccsb 7.40@82mph with a broke trans.
Lord help me be the man my son thinks I am.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
