Pwnm30rdi3
Hey guys, dealing with another problem...
I've got this driveline vibration at 60+ mph. Stock ride height, no lift. Brand new tires, have had them balanced twice. Carrier bearing seams tight and in good shape. I've already installed new u-joints.
I have had 2 shops tell me that I had positive pinion angles and that the driveshafts were likely binding on themselves (because it's a 2 piece shaft). So, I had a frame & alignment shop throw in 1.5 degree shims which seemed to clear up my vibration at 40-45mph, but my 60+ mph vibration is still present.
Rewind to when I rebuilt the motor 12 months ago. I took the driveshaft out and to a local axle shop and had them balance the shaft. They are the most popular axle and driveshaft shop in Indy.
So the first shop that installed the shims, suggested that I take the driveshaft back and have them re-balance.
Yesterday I dropped my truck off at the driveshaft shop and told them to re-balance and fix the vibrations. I got a call today from said driveshaft shop. They are blaming the majority of the vibration on my motor, but they think that the rear u-joint is too tight. So I told them to pull it and inspect. This driveshaft shop said that I need to take the shims out because they aren't helping.
So what are your opinions?
Isn't it basic knowledge for "driveline specialists" that you aren't supposed to have the pinion nose pointing up, but that it should be parallel to the carrier bearing?
