Go Back   PowerStrokeArmy > Power Strokes > 6.7 Tech
Reply
Thread Tools Display Modes
  #1
Old 11-07-2019, 05:39 PM
Motostroker's Avatar
Motostroker Motostroker is offline
Major
Member's Gallery
Default Annoying exhaust tick noise
Installed a fleece charger on the truck. While I was at it I installed new exhaust manifold, and uppipe gaskets.
All oem gaskets and properly torqued everything. I made sure the uppipes seated to the charger as well. Torqued the manifolds, etc
I had a regular (non baffled) CCV deleT.E kit on the truck. I got tired of it losing a quart between changes. So I installed an old Absolute Performance Baffled CCV Kit I had laying around the shop for the past 4 years.
Throw it all together. Sounds like a exhaust leak coming from the driver side. (Not the typewriter tick these 6.7s have) but a very audible tick that increases with RPM.
I dissemble and install new gaskets again. (Just making sure)
Noise is still there.
Injector tick/knock? IDS shows a smooth balance on all injectors
This noise is annoying.
Anyone else have this issue?
Does this baffled CCV amplify noise like a microphone?
Sent from my iPhone using Tapatalk Pro
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
