Go Back   PowerStrokeArmy > Power Strokes > 94-97 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 11-04-2019, 06:48 AM
KBMKVIII's Avatar
KBMKVIII KBMKVIII is offline
Major
Member's Gallery
Default 05+ trac bar bracket for OBS
I have been looking for a while and Im having a hard time finding a trac bar bracket made for the OBS to 05+ suspension conversion. I know RYD makes them, but for the price I think there has to other options. $350 seems way too high. Suggestions?
__________________
96 7.3. PIS 350 200s. Precision Turbo 76mm. Big Oil.
18 Cummins 2500 White Laramie Sport.
Stock with a warranty
  #2
Old 11-04-2019, 08:33 AM
CJunkie's Avatar
CJunkie CJunkie is offline
Corporal
Member's Gallery
Default
I think Sky's off road is making a kit, but I'm not sure if its out yet. You would have to check their website. That's the only other source I know of.
Sent from my SM-J320V using Tapatalk
__________________
97 F250 SCLB 7.3 4x4, 303k and counting
zf5, 6637, TS chip, dual 4" straight pipes
Currently looking for axles for an 05+ swap.
  #3
Old 11-04-2019, 09:18 PM
JCart JCart is offline
Sergeant
Member's Gallery
Default
Speak with Trevor at Precision Metal Fabrications. He makes a number of RSK conversions. Bought my pan hard bar with drop bracket for my 97 D60 conversion. Heim joints both ends very robust.
Cheers
j
__________________
'97 F250 ECLB Tan White Tan Now ZF5 , 4:10s, D60, PMF 3.5 RSK, 37 Toyo RTs Anti sways front/rear w rear bags 5 blocks (184,000 Kms) DP, intake and 4 exhaust, FFD 205/30s, Hydra, E fuel.
Truck pix & Write ups
  #4
Old 11-07-2019, 09:45 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Quote:
Do you think you could modify anything to make a frame track bar bracket fit off of a 11-16 front end? If so i have one you can have. Just pay shipping.
live life full throttle
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #5
Old 11-07-2019, 03:15 PM
KBMKVIII's Avatar
Major
Member's Gallery
Default
I have no idea. You have a picture of it?
__________________
  #6
Old 11-08-2019, 06:17 AM
General
Member's Gallery
Default
No but when i get back to Michigan i can. Or google it.
__________________
  #7
Old 11-08-2019, 06:18 AM
General
Member's Gallery
Default
I know strokersace had a coil sprung obs but not sure what setup he had. Maybe pm him too..
__________________
  #8
Old 11-08-2019, 06:44 AM
KBMKVIII's Avatar
Major
Member's Gallery
Default
Thanks guys.
When you coming back to Michigan Lincoln?
Im in the Brighton area.
__________________
  #9
Old 11-08-2019, 09:08 AM
Strokersace's Avatar
Strokersace Strokersace is offline
Colonel
Member's Gallery
Default
I used the factory 05-07 track bar bracket. But to do so I had to heat up the front of the cross member and reshape it slightly so there was a flat area to bolt it to. The. Drilled holes to attach.
Worked VERY well but was VERY time consuming. Especially with the engine and everything in place still. Although the manufactured bolt on brackets are more expensive, they might not be anymore expensive and maybe cheaper once you factor in YOUR labor cost.
There wasnt any other options at that time other than a weld on bracket. And I DID NOT want to weld anything to make the swap work. Glad I didnt either because I was able to unbolt everything when I swapped that suspension to another truck and put the obs to a rsk with SD springs and axles before I sold it.
__________________
I'm sweatin' like a wh*re in church here!
  #10
Old 11-08-2019, 09:13 AM
General
Member's Gallery
Default
Thanks guys.
Sunday... i have drove through there a million times in the past few years.. lots in the last 6 months especially.. Lol.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
