Go Back   PowerStrokeArmy > Power Strokes > 6.0 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 11-08-2019, 10:10 AM
Diesel625 Diesel625 is offline
Sergeant
Member's Gallery
Default 06 getting some work done
After buying a new truck to replace my 06 dually, I realized I missed using my old truck. Iím sending it in to get studded, new lifters, and probably a cam as well. It was used as my welding truck, and to tow my 40ft gooseneck with materials for some of the jobs I do. I currently have a kc stage 1 turbo, sct 5015 running custom tunes, egr ******, blue spring, 5Ē cat back exhaust, oem injectors with 20k miles, and all updates. What would be a good cam to run? I was thinking of a stage 1. A dynamic diesel stage 1 is what was recommended to me. Also, what bead gaskets would be best to run?
  #2
Old 11-08-2019, 10:51 AM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
Quote:
Absolutely NOT a Dynamic Diesel cam. Iíve used a variety and my favorite is a Colt Stage 2.
Iíve used an untold number of the Mahle upper gasket kits (HS54450 if itís 18mm, HS54579 if itís 20mm) and have had excellent results, ie, no failures or come backs.
Also, I always torque my ARP 2000ís to 225 ft lbs with ARP Lube on the threads and nuts.
  #3
Old 11-08-2019, 10:58 AM
Sergeant
Member's Gallery
Default
Colt is what I was wanting. Just seeing what other members thought of the dynamic cam. Mahle are the gaskets I was wanting. I’m hoping the cam looks good and I can spend a few dollars elsewhere. I was also thinking of an odawgs intake.
  #4
Old 11-08-2019, 01:36 PM
CTC DEEZUL's Avatar
CTC DEEZUL CTC DEEZUL is offline
General
Member's Gallery
Default
I'd get a new cam and factory lifters.
__________________
Teamsters Local 444- Rolling Coal United
  #5
Old 11-08-2019, 02:49 PM
Sergeant
Member's Gallery
Default
Factory or aftermarket cam? Factory lifters are probably what I’m going with.
  #6
Old 11-08-2019, 09:07 PM
Sergeant
Member's Gallery
Default
Here’s what I’m planning on doing after all. New oem lpop, colt cam stage 1, oem lifters and pushrods, upgraded valve springs, studs, oringed heads, regulated return, airdog system, front cover, and reseal the whole engine. I’m debating on what injector size to run. I was thinking of 175/30s, but was thinking of maybe doing 190/30. I’m running a kc stage 1 turbo. How would this setup run? I’m hoping it will be a good tow setup.
  #7
Old 11-08-2019, 09:44 PM
6.0 Tech's Avatar
6.0 Tech 6.0 Tech is offline
Colonel
Member's Gallery
Default
Factory lifters, as said. Never ridden in a colt stage 1 truck, but the 2 pulled a hell of a lot better and made about 30 more hp than my truck with a rcd stage1 cam, all other things were the same, injectors, turbo, etc. From reading in the 6.4 section I wouldn't deal with dynamic if my life depended on it. Do a search there, and judge for yourself. Id recommend the 190/30s personally. They run great, will run just like a 175/30 normally, but you'll have the extra if needed in a race tune. Remember that tuners tune to nozzle size typically, not body size. Daily and towing the injectors will run identical, but if you get a wild hair, the 190s will make more power in a race tune.
Sent from my VS988 using Tapatalk
__________________
04 cclb IDP and TSD tunes, KC Stage 2 hi pressure, S476 atmosphere, Odawg Stage 2 ported intake, RCD Stage 1 cam, RCD lifters and pushrods, RCD 120# valve springs, ARP 625s, o ringed heads, Warren 7mm 250/100 hybrids, Strictly bowl dereete regulated return, Air Dog 2 4g, Snow stage 2 water/meth
  #8
Old 11-09-2019, 07:09 AM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
Hereís what Iím planning on doing after all. New oem lpop, colt cam stage 1, oem lifters and pushrods, upgraded valve springs, studs, oringed heads, regulated return, airdog system, front cover, and reseal the whole engine. Iím debating on what injector size to run. I was thinking of 175/30s, but was thinking of maybe doing 190/30. Iím running a kc stage 1 turbo. How would this setup run? Iím hoping it will be a good tow setup.
Youíve got a pretty good plan.
Things Iíd change:
Colt Stage 2 versus a 1
If you do upgraded valve springs do stiffer pushrods
190/30ís for the reasons Tony mentioned
Donít use an Airdog. If you want to PM me Iíll give you some fuel system recommendations.
  #9
Old 11-09-2019, 09:59 AM
Sergeant
Member's Gallery
Default
I know some people modify the pistons with a stage 2 cam. Is that necessary? What size spring should I run with the stage 2 cam?
  #10
Old 11-09-2019, 10:20 AM
ncollins64's Avatar
ncollins64 ncollins64 is offline
Colonel
Member's Gallery
Default
If budget allows you could also look into the hylift Johnson upgraded lifters that RCD sales. I’ve used several sets on some big builds with zero issues and pretty sure Josh uses them on his big builds as well. I think there well worth the money over stock imo. Also been using the stage 1,2, and 3 valve springs and pushrods from Kill Devil and just buying them from KC.
__________________
ē2013 F350 CCSB PLATINUM
ē08 F-350 CCSB 950/1493
Midwest Diesel, Elite Diesel, RCD, OUO, No Limit Fab, PMF Fab
ē1997 F-350 7.3, srw, rclb, 4wd, 5speed (work truck)
ēPast rig: 2000 F-350 ccsb, 1100 hp 6.7 cummins
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
